Calling all PE folks....and anybody who might be of help please.
James02
415
N.Y.S.
I cleaned my flue tonight, and I always have a tough time getting the pin for the baffle back in. This time I sorta put it in backwards so it isn't flush....It's bothering me, and I need to correct it tomorrow. Problem is, it seems as if the baffle goes up in the rear ever so sleightly and the holes don't line up...Is the baffle warped...I checked and its not sitting on debris or anything....help!
In fact I can hear the air (and heat) rushiing out....arg!
Is the baffle sitting correctly & aligned with the tube that it sits in, in the back of the stove?
Its as far back as it can go and flush, but I couldn't get the pin in...so I turned backwards and rigged it sorts so it would hold steady.
The pin doesn't do much, whats this air you are talking about?
If the pin doesn't go in correctly, chances are the upper baffle isn't installed correctly.
They can be a little difficult to get in even if the baffle is in correctly, if the baffle is not in correctly you will know it with out a doubt, it wont set right at all.
From the Vista manual :
"Baffle Removal
The baffle may be removed from the firebox to clean and
inspect the chimney liner.
DO NOT OPERATE WITH BAFFLE OR INSULATION
REMOVED.
Removal
Remove retaining pin at the back top of the fi rebox, just
under the baffle. Remove rail extensions in front of the baffl
e by turning and lifting out. Lift baffle up and pull forward
to disconnect from the supply tube. Tilt baffle sideways
to drop down and remove from firebox. Inspect gasket
between baffle and supply tube. If necessary, replace with
gasket #139.5 available from your Pacifi c Energy dealer.
Re-install baffle assembly by reversing order."
The supply tube is key, If the baffle isn't in correctly, the pin won't go in.
It wont set right at all and you can tell its not down on the supply tube, it will be way off not just a little.
Yea, everything is as normal....I've always had a tough time getting it back in....this time my back said "no more"!
I'm bumping this up, but I still think it's a baffle install issue..
I had a rough time with the baffle & pin in the PE the first time we did it, and I know how hard it can be to install it.
Well I just had mine out and it sets on a lip and if you dont get it in place it is whopper jawed pretty bad, my point is until I got it to drop down on the lip it was obvious it was not in place. I'm guessing but we are talking 1/8 inch vs at least 1/4 inch.
The pin and hole are not perfectly matched, Mine actually has two holes next to each other, good QC huh? When I put my Hog style gasket in, it is obviously thicker than the original gasket material. So the holes didn't line up, a pair of vice grips holding the pin and a little turning back & forth does the trick for me.
Does your stove have the 2 side rails that the baffle sits on? Mine are free-floating and if not set level the baffle will be off kilter. I had my baffle actually slip off the railing about a quarter inch on one side. You can try playing with those and see if it helps any. Just an idea...
Agree and/or the insulation is wedged between the baffle and rail -->> raising the baffle. Or rails inverted/switch sides etc. The rails can be a pain to get in place properly and keep in place while maneuvering the baffle into place.
If/when you remove the baffle to get a better look at the problem(s), take the time to shop vac out the rear air channel going to the baffle. And make yourself a hog gasket.
I am curious as to what noise you are hearing as well.
Take some pictures and post it in this thread
Did you plug the air supply tube before you cleaned the flue? It is important to cover the air supply tube to prevent ash from collecting in it during the sweep. What was the condition of the baffle gasket? Did you replace it?
You could also have flue ash etc. that built up around the air supply tube during the clean out. That could raise the baffle and not allow it to sit properly around the air supply tube. I would remove the baffle and take a brush and/or vacuum and clean around the air supply tube. Just make sure to carefully remove the baffle gasket first, if it is in good condition and you are planning to reuse it.
Thanks to everybody for their replys...I got a bit tired of fussing, so I've been running it without the pin. I am going to see what happens after my next cleaning. I'm hoping to upgrade next year anyhow...
