    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. truck243 Member
    louisville ky
    We have an old majestic woodburning fireplace model m36f766772, can we convert it to a gas log fireplace?
    #1
    Helpful Sponsor Ads!
  2. webby3650 Minister of Fire
    southern Indiana
    Sure, just make sure the fireplace and flue are cleaned first. You could also install a gas insert, more pricey, but would be efficient and would look real nice. Kingsman makes a real nice unit. http://www.kingsmanind.com/fivented
  3. pen Super Moderator
    N.E. Penna
    adding this thread to the gas room.
    pen
  4. DAKSY Super Moderator
    You can probably do it, but make sure it's UL approved to burn gas.
    As Webby said you may also be able to put an insert in inside the fire
    box, but they tend to be quite small, don't throw a lot of heat & aren't
    really that nice to look at. If you have the money, & are dead set on
    burning gas for the convenience, have it torn COMPLETELY out & have
    it replaced with a Gas-Burning FIREPLACE. You should be able to get a
    unit that is nearly identical in size that will also give you heat during a
    power failure. Keep in mind that this is about an 8 hour project & it IS
    costly, but a qualified, responsible Hearth Shop will do the job so well,
    that you shouldn't even be able to tell that they were in your home...
    HTH
