Hi to you all from a newbie!
Just fitted a Morso 1412, lovely little stove. But really struggling to get it to burn well - temperature on my flue thermometer rarely goes above 100 deg C and if so only slightly.
For info it is fitted with a double insulated 6" 904 liner which is about 9 meters, Leca insulation (only a half bag as had great trouble getting it in!), back exit from stove into a T piece, 1 foot stove pipe in 5" to a 6" expander above register plate. Confident the liner is the right way up! No reason to think I have any leaks or sharp curves.
It lights easily with both vents full open, once it's up and running I close the bottom vent. Burning wood just now which I believe is well seasoned. Not got a moisture meter. Yet, hoping Santa will bring one! Was trying to burn stuff that was too big initially so have reduced the size of my fuel.
But I have to leave the top vent open all the time and I've noticed that if the door is open a crack it instantly flames up much better. Close the door fully and even with top vent open eventually a well burning piece of fuel will slowly burn down and go out. Am I looking at a draw issue?
Apart from getting some kiln dry wood to prove the wood is the issue, or not, my only thoughts are;
Might I be drawing air from the T piece bottom access cap. At the moment it is just fitted in place but not sealed with fire rope or similar.
Liner terminates at the bottom of my chimney pot on instructions of the fitter (he wanted it 18" below top of pot height but it wasn't possible, pot height is about 10"). I thought liner should terminate half way up to, or full, pot height?
Some bricks fell down when we were fitting liner, if it were dented would it be affected?
Any other comment welcome,
Thanks,
Peter
Thanks,
Peter
