I've been using Carlton chains that are made up from a bulk roll at the local hardware store, the problem with them is they stretch way to much.Just kind of wondering what kind some of y'all use?
Heat is what causes chain stretch. Dull chain is what causes heat.I have been using Oregon. All chains have some stretch, but I have not had any issues with the Oregon.
So if I put on a new chain that is being used in a correct way am I going to have chain stretch?
I dunno who told you this but it's wrong. Chains don't get nearly hot enough for that heat to be the cause of the stretching. Also, common sense and experience say otherwise: chains stretch most when new and new chains are sharp chains - as sharp as most chains are ever likely to be.
Bigg Redd says heat don't stretch a chain. I've only ran chainsaws for 45 year and own and operate and sawmill. Better listen to Bigg Redd. He has 3500 posts on the internet. Don't see how he has time to run a chainsaw.I use carlton and windsor, and have never had a problem with either. They stretch a little when they are new, and very little after that.
I have heard (from their marketing dept) that Stihl chains stretch less than other brands...........for what it's worth.
You have to get a chain pretty hot (which is operator error that will be passed along regardless of brand) for it to stretch "too much". I have done it (ground cutting stumps a few years back, every cut was basically in the dirt and we just forced it through and kept tensioning the chain), but it really takes a lot.
Big Red, you ever felt your motorcycle chain after riding awhile--It get hot as hell. I ride a ZX14 you dumbass.Bigg_Redd says your entire premise is flawed (see below). It doesn't even pass the laugh test.
Just a question - how hot does your chain get? What's it made out of? Carbon steal? Chrome steal? Mild steal?
My motorcycle chains stretch too. Is it because they are dull? Maybe with all that time you're not posting you can look that up for me. . .
Hot enough that you can't touch it after a 50 mile interstate run. Running the chain on a chainsaw too tight is another cause of excessive chain stretch caused by excessive heat.How hot? 200*? 250*?
All chains stretch a bit when new. That is why saws come with an adjustment to tighten the chain. If the chain is stretching so much that you can't tighten it anymore than you have the wrong size chain. I have a few time not tighten the bar enough, after a while the chain loosens up. what kind of bar and chain oil do you use?I've been using Carlton chains that are made up from a bulk roll at the local hardware store, the problem with them is they stretch way to much.Just kind of wondering what kind some of y'all use?
