Chimney cap clogged!!
sixman Posted By sixman, Dec 24, 2010 at 5:28 PM
Thread Status:
  1. sixman
    sixman
    Feeling the Heat 2.
    NULL
    Apr 12, 2010
    257
    2
    Loc:
    Central Texas
    First year burning wood question for the panel. Is it normal to have to clean the wire mesh inside the cap due to it being clogged during the heating season or am I burning wrong?
    Wood is dry, 3-4 years old and the black stuff was a crunchy dry texture. I ran a screwdriver around inside the mesh and tapped on the mesh to jar it loose and dumped it out.
  2. mywaynow
    mywaynow
    Minister of Fire 2.
    NULL
    Dec 13, 2010
    1,369
    367
    Loc:
    Northeast
    I am seeing a similar build up along with some dripping from the cap seam, down the pipe. The cap is not blocked at all, but is getting a shinny black residue on the downwind side. Only burned about 2 weeks now, 24/7. Similarly concerned.
  3. rdust
    rdust
    Minister of Fire 2.
    NULL
    Feb 9, 2009
    4,287
    947
    Loc:
    Michigan
    It's not uncommon for caps with a fine screen to get plugged up. I've heard of people taking the screens out or cutting the openings bigger.
    How does the pipe look? If the inside is clear without any nasty build up I'd say you're burning fine.
  4. branchburner
    branchburner
    Minister of Fire 2.
    NULL
    Sep 27, 2008
    2,684
    336
    Loc:
    southern NH
    Last year I had a gallon of black crunchy stuff on my cap/screen/chimney crown, and only a pint of fine brown powder in the entire 20'+ liner. I think it is pretty normal for creosote to condense on whatever it hits once it leaves the stack. Inside the stack is what you want to keep an eye on.
  5. Wood Heat Stoves
    Wood Heat Stoves
    Minister of Fire 2.
    NULL
    Jun 12, 2009
    1,905
    14
    Loc:
    Nevada City, California
    yes, +1
  6. tcassavaugh
    tcassavaugh
    Minister of Fire 2.
    NULL
    Jan 10, 2010
    1,025
    146
    Loc:
    Southern Maryland
    +2 I get it a the top on the cap. Sometimes pretty bad, sometimes not. Dependant on the moistuer of the wood and temperature i think. Also, if you burn at slower burns, i think it tends to accumulate because the gasses are cooler and can condense easier. I just crawl up on the roof about mid January and run a brush down the pipe (not bad normally) and knock the stuff off the cap.
    cass
  7. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    South Puget Sound, WA
    We get several reports of this every year. Clogging is an indicator of too cool flue gas temps or in some case too much particulate, usually from burning a lot of paper or cardboard. Cool flue gases can be caused by running the stove too cool, wood that has higher moisture content and/or a long, cold, exterior flue. In the last case, there may be little you can do besides remove every other grid of the screen mesh to effectively double the size of the screen holes.
    FWIW, I've had stock cap screens on flues for the past 17 years and have never seen an issue with clogging. Both flues have been straight-up, interior up to class A, with about 7' exposed to outdoors.
  8. lumbajac
    lumbajac
    Member 2.
    NULL
    Mar 15, 2008
    85
    0
    Loc:
    Upper Peninsula, Michigan
    Can a chimney cap be unclogged by sweeping chimney from stove side up with flexible brush?
    No way I'm going up on my pitch of roof with snow on it... 2 stories with 10/12 pitch. Might have to I guess, but it's tricky enough with a dry roof.
  9. Treacherous
    Treacherous
    Minister of Fire 2.
    NULL
    May 13, 2010
    999
    119
    Loc:
    WA state
    Early in season I burned wood too cool in my stove and got some clogging in my screen. Nothing blocking things off but enough to make me concerned. I was able to clean the screen remotely with a couple long paintbrush poles I picked up at Lowes. I connected a small wire brush to the end of poles. My roof is steep as well so this was a good compromise that allowed me to clean out the screen. I just need to get someone up there to remove the screen next spring. Too much ice and snow on the roof right now for any safe access.
  10. Renovation
    Renovation
    New Member 2.
    NULL
    Oct 26, 2010
    1,087
    3
    Loc:
    SW MI near Saugatuck
    Good to know, thanks.
  11. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    It will help. Got an accurate pellet rifle?
  12. sixman
    sixman
    Feeling the Heat 2.
    NULL
    Apr 12, 2010
    257
    2
    Loc:
    Central Texas
    I know I am burning too cool but I can't help it. The rest of the chimney looked good. The guy that sold me the stove and pipe also sold me the spark arrester or screen that goes in the cap. Since I have a metal roof do you think it would be okay to remove the screen?
  13. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    I'd just open it up if need be. It won't take more than about 15 minutes with a pair of good diagonal cutters. Curious, why are you burning cool?
  14. Mad Tom
    Mad Tom
    Member 2.
    NULL
    Jan 19, 2010
    244
    1
    Loc:
    Vermont
    A .22 works a little better. Just don't do it early in the morning dressed just in your boxers. The neighbors might be out walking their dog.
  15. sixman
    sixman
    Feeling the Heat 2.
    NULL
    Apr 12, 2010
    257
    2
    Loc:
    Central Texas
    Texas weather, gets too warm in the house.
  16. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    Yeah, you folks are on the cusp and getting fickle weather. It's 40F in Ft. Worth and 70F in Houston. Best thing to do is to burn smaller, hotter fires. Less wood = less heat. It will require more frequent feeding, but it will keep you off that slippery roof.
  17. wkpoor
    wkpoor
    Minister of Fire 2.
    NULL
    Oct 30, 2008
    1,854
    82
    Loc:
    Amanda, OH
    First year I started burning/heating with wood I promptly chucked the spark arrester cap and installed a plain rain cap. My chimney is 35' and is only accessible by ladder. Can't take a chance when stove is my only heat. Wind tore off one rain cap a few years ago and I just went without totally the rest of the season. Don't really need a cap in the heating season.
  18. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,338
    2,084
    Loc:
    Cascade Foothills, WA
    I disagree. Clogging is only an indicator that you have a mesh filter on your chimney cap. While you are more likely to clog your cap with poor burning habits, the fact that your flue has clogged is not enough to conclude poor burning habits. Only the combination of the ideal stove, habits, wood, and chimney setup will allow you to run with a mesh cap and not experience pluggage more than once per year.
    My cap's screen would plug every few months until I removed it. The entire length of the chimney which is very similar to BG's would barely accumulate a couple of cups of creo over the whole 9 month burning season. It's mesh.
  19. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    Where did I say poor burning habits? Some flues run cool due to location and length. Sometimes it's the wood. And all caps are not created equal. What I did say is after 17 years of burning in this house in two different flues, the mesh has never clogged. Next year for whatever reason, I might be burning damper wood and it could clog. The point is that it is possible to burn and not clog the screen.
  20. joefrompa
    joefrompa
    Minister of Fire 2.
    NULL
    Sep 7, 2010
    778
    1
    Loc:
    SE PA
    Just get your stove top reading 700-750, put a fresh load of wood on, then open up your flue all the way and your intake.
    You want 1400 degree exhaust gases wooshing up that flue so hard that it blows your cap clear.
    Joe
    P.s. This post was 97% in jest.
  21. kgrant
    kgrant
    Member 2.
    NULL
    Jan 17, 2008
    154
    5
    Loc:
    Fairbanks, Alaska
    My caps are easy to access and I burn 24/7 so durning the heating season I don't run caps. Take them off and the fall and put them back on in the spring.
  22. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,828
    8,597
    Loc:
    It depends on your climate and region. I wouldn't advise someone living in tinder dry mountains like western CO to run without a screen. Nor for folks in urban areas. But in our wet Pac NW, or winter snowy Fairbanks, probably not a big deal.
  23. Pagey
    Pagey
    Minister of Fire 2.
    NULL
    Nov 2, 2008
    2,424
    33
    Loc:
    Middle TN
    3% is good enough for me, baby! *Fires up stove and opens bypass damper*
  24. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    I recall one time having the screen on the cap. We used to just stand on the ground and using a small light pole, would just tap the screen and the stuff would fall right off. Wear goggles!
  25. sixman
    sixman
    Feeling the Heat 2.
    NULL
    Apr 12, 2010
    257
    2
    Loc:
    Central Texas
    I am thinking that I could get away with taking it out of the cap. It did not come with the cap but installed at the recommendation of my salesman. I have a brick home with a metal roof so the only combustable near it would be the grass in the yard. Do you guys that don't have one see actual glowing embers leaving your stack headed for the ground?
Thread Status:
