Chimney cap-- reducing the draft.
mainstation
344
N.Ont.
I am looking for a chimney cap that might help reduce the draft on my flex liner. Is there such a product. Any links would be helpful, Thanks all.
I think what you really need is a stovepipe damper.
Besides, there may be some days where you want
all of your potential draft.
There's lots of people who would like to be in your shoes......
Sounds like mainstation might be burning an insert, as the term "flex liner" is in the post. If that's the case, there's no way to install a stovepipe damper, because...there's no stovepipe. We could use some additional info about the installation. Rick
Yes insert, sorry. I will be replacing an old Regency which could runaway from time to time, mostly due to poor door seal and slight warpage. I have an exterior stone chimney, approx 28' tall facing North with heavy W/NW winds all winter to supply plenty of natural draft. My local stove shop said there is a better cap to help with drafting issues, I just cannot remember what or who made it.
Thanks.
They might have been referring to a cap like a Vacu-Stack, specifically designed to address certain types of draft problems, but this is probably not what you need, as it is designed to ensure that wind increases the draft, not reduces it.
As long as everything seals well and the air inlet shuts down far enough, I would think you'd be ok. Might be better to try it with the insert before you start looking into modifications you might not need.
Nice signature, by the way!
The only reason why I mention the damper option is
because we have also have a flex liner, but it tees out
to a stovepipe & woodstove on the bottom. And yes, we
do have a stovepipe damper on our flue. Makes a world
of difference in the right circumstances.
mainstation said:
Yes insert, sorry. I will be replacing an old Regency which could runaway from time to time, mostly due to poor door seal and slight warpage. .
Why not remedy this instead MStay?
Understood, Rob. Makes sense. Glad that works for you in your installation. Did you put the damper in originally, or retrofit it after learning how the system burns? Rick
That is in the works, probably going with a P/E Summit insert.
There are days when our flue drafts like a bandit, and it is nice to regulate it some.
Also, when it drafts well, we get great burns and longer burn times when we
"double damper" our woodstove (turn air control down & damper).
