    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Joful Minister of Fire
    Philadelphia
    I got some pricing for pulling my gas insert and liners, and installing the new liner for my woodstove. I have no problem with paying a fair price, so I'm just looking for a nod from the pro's here on this being a fair price. I'm in southeastern PA.
    Mantel shield: $50 x 2 for my 48" wide wood lintel
    chimney liner (6" x 25'): $520
    quick connector (6"): $65
    liner cap (screen / no wind guard): $65
    standard top plate: $65
    insulation kit: $389
    6" spark arrestor: $0
    labor: $899
    remove gas insert: $150
    level 2 inspection: $300
    TOTAL: $2553
    I may pull the gas insert myself to save that $150, so just wanting to be sure everything else looks fair. It's certainly more than I've paid for any other chimney liner, but this is the first insulated liner I've done (old chimney is stone with no clay liner, so they want to do an insulated liner), and the insulation adds $400. The level 2 inspection is because it's a 240 year old chimney, and this company had a house fire in a similarly old chimney last year, due to unknown combustables running thru the chimney.
    Thanks!
    #1
    Helpful Sponsor Ads!
  2. mellow Minister of Fire
    Salisbury, MD
    What is level 2? Do they inspect with a camera before installing the insulated liner?
  3. Joful Minister of Fire
    Philadelphia
    Yep. I guess their "level 1" is to stick their head in from both ends and look around, or perhaps use a mirror to see farther into the chimney. "Level 2" is to lower a camera down into the chimney and look for any potential problems. After their fire last year in a similarly old home, they're pretty adamant about doing this inspection. They actually bring in an outside inspections company for this part of the job, perhaps to distribute or defer the liability.
  4. TradEddie Feeling the Heat
    SE PA
    That inspection sounds like BS to me, installing the liner, especially an insulated one, means that the existing chimney is no longer exposed to significant heat. It does need to be cleaned well before installing the liner.
    Get some other quotes, I did, and saved almost $1000. I used Gasworks in Malvern, very pleased with them.
    TE
  5. mellow Minister of Fire
    Salisbury, MD
    Just food for thought, I was charged $150 to send a camera down mine. It is a very good thing to do and sometimes they can even give you the video of it if your into that sort of thing.
    I did the camera for peace of mind, then installed an insulated liner myself.
  6. Joful Minister of Fire
    Philadelphia
    Good to know. I think the camera work might be more expensive in this case because they have to get WAY up there (cannot reach this chimney with a 40' ladder), and they're calling out a separate company to do it, not the same company that's doing the rest of the work. I hate paying for stuff like that like I hate paying for insurance, but I think it would be foolish to skip it if there's any concern about the chimney construction, so I'll be going thru with it. $300 is mighty cheap insurance when it comes to the possibility of a fire.
  7. clemsonfor Minister of Fire
    Greenwood county, SC
    BUT the whole point of a liner it to eliminate any old or suspect chiney as well as to allow your device to function properly?
  8. KarlP Feeling the Heat
    When I first bought my house in '99, I paid for a chimney sweep with a good reputation to professionally clean and then send a camera down my chimney looking for any cracked tiles or bad mortar joints. What they did was run a brush up and down once, stick a Canon point and shoot through the thimble, snap four or five pictures, and hand me a huge bill. By the time it came time to install a liner, I was a much smarter consumer and did it myself. :)
  9. Joful Minister of Fire
    Philadelphia
    According to more than one local chimney sweep, they have found wood running right THRU some very old chimneys in this area. This particular stove shop had a customer with a serious fire last year, due to exactly this problem. They peered in from above and below before installing the liner, and did not see anything of concern, but that's apparently because the wood was charred completely black and was not easy to identify mid-chimney. In any case, the liner was up against it, and about a year after the install, finally got hot enough to set fire.'
    Again... a very unlikely scenario, but $300 for the camera work is very cheap insurance to this owner of a 240 year old house.
  10. mellow Minister of Fire
    Salisbury, MD
    At that age of house you never know what you might reveal from the camera going down the flue, I think it is a smart investment as well, but I would call around to make sure you are not being gouged.
  11. remkel Minister of Fire
    Southwest NH
    My sweep ran a camera up and thank god he did. Almost fell over as I watched the images on the screen. I think he saved the video as an example for others.
  12. Blue Vomit Minister of Fire
    eastern PA
    I'm no expert, but I think you could get 25' of a decent insulated liner for less than $900.
    Good luck
  13. bluedogz Minister of Fire
    NE Maryland
    My 30' kit from Rockford was under $900. 'Course, I had to feed Hogwildz.
  14. Cross Cut Saw Feeling the Heat
    We had a 30' Chimney liner installed, it included the double wall stove pipe for $2500.
    I had gotten a slightly less expensive quote but I felt the overall service from the guys I had install it was worth the difference.
    http://www.mainecoastchimney.com/
    I was ready to drop a pretty nice chunk of change on a stove he sells but because he knew we wanted something to burn full time and that would go all night he suggested the Progress Hybrid we bought. He gave up several hundred dollars in profit to get us what we NEEDED, that's called integrity!
    The other dealer who will remain unnamed was more than happy to sell us anything just to make the sale.
  15. Cross Cut Saw Feeling the Heat
    It also included creating a clean out which the chimney did not have and the wall thimble etc. pretty much everything from the stove top to the chimney top installed.
    It also came with a lifetime fully transferable warranty...
  16. Armoured New Member
    Russia
    So what did he find that was so notable?
    Joful likes this.
  17. mellow Minister of Fire
    Salisbury, MD
    I know when they did mine they showed me the cracks in the terracotta and how much creosote was still in them, the brush could not get into those cracks, so the next chimney fire would have ignited what was in those cracks and possibly transferred to the house structure.
  18. remkel Minister of Fire
    Southwest NH
    Well,
    First, we found a thick coating of glazed creosote from bottom to top. Then we found that the mortar between all the liner sections had come out.
    Final result was that I had an SS insulated liner installed and that my friends has made all the difference (oh, and replacing the old Vigilant with a new Jotul)
  19. Joful Minister of Fire
    Philadelphia
    Well, this is interesting. My liner install price just went way up. My chimney is approximately 40 feet, and the internal flue is 18" x 18". No problems there. However (PROBLEM!), it necks down to 9" x 9" at the top, and the interior is completely WOOD in this area! That's right, folks... they necked an 18" x 18" masonry flue down to 9" x 9" with wood timbers, at mid-attic height. The exterior of the chimney is all masonry, but tapers from approximately 8' x 6' external down to 5' x 3' external at this point. The upper part of the masonry stack is supported by wood timbers inside the chimney.
    Who was saying the camera inspection was a waste of time?
  20. mellow Minister of Fire
    Salisbury, MD
    Now the question is, with wood being exposed like that which liner manufacturer will support an insulated liner being put next to wood of that age?
  21. Joful Minister of Fire
    Philadelphia
    Good question. The inspector has to talk with the installer (two separate companies), and do a little brainstorming. The inspector said the full code fix would be to remove the upper 10 feet of masonry stack, which takes you down into the attic thru a metal roof, and into an exterior stucco over stone wall, remove the timbers, build a new stack with new flue, and repair the raised seam metal roof to suit. All more than 40' off the ground, at a cost of perhaps more than $20,000. He's confident they can find a safe and much less costly solution, although he anticipates it will not be code, and will require the granting of a code variance. I think he'll be talking with the installer in the next day or two to kick around some options.
  22. mellow Minister of Fire
    Salisbury, MD
  23. Joful Minister of Fire
    Philadelphia
    Perhaps an option, although considering it is wood timbers that necks the flue down from 18" to 9", I imagine even a cast lining might be a problem. After all, it cannot be thicker than 1.5" if reducing 9" to 6", and it would be cast right on the wood. Perhaps fine while in good shape, but likely due to crack as the wood exhibits seasonal movement year to year.
    One idea the inspector tossed out in our quick conversation at the conclusion of the inspection was possible double-insulating a stainless liner, with two layers of fiberglass and foil insulation. However, he's an inspector and not the installer, and the installer may have other ideas.
  24. mellow Minister of Fire
    Salisbury, MD
    I would still give supaflu a call, they have worked on many old restoration projects and have probably come across this situation before.
  25. Joful Minister of Fire
    Philadelphia
    Good idea. I'll put them on my call list for tomorrow. Thanks!
