Hi everyone. So glad to have someone to bounce some questions off of. I have a Lopi Insert and it's being installed in an existing masonry opening. The flue is 8"x8" most of the way and is a bit wider at the bottom.
Several years ago we demo'd the upper section of the chimney which was falling down anyway and had to go, in order to tie in a new room addition. We liked the hearth and fireplace so we only took the chimney down to the ceiling level on the first floor.
Now we want to install a wood burning insert.
The problem is with chimney liner and the connection of a liner to some Class A. I'm told there is no way to do this, so I am wondering what you folks my have to say about how I should chimney this insert.
The insert is designed to vent directly into the firebox but I don't want that at all. When I pulled the old stove out it was amazing how much debris was in there and I don't want that.
Here's a sketch of the layout.
I'd be interested in how anyone would design a chimney for this insert. It's 8" discharge.
I wanted to use flex chimney liner to the top of the masonry and convert to class A above that, but I'm told there is no way to make the transition. Any ideas would be most helpful.
