Class A double wall terracotta cap/?
snaple4
284
AR
Is there a terracotta chimney cap/plate that I can use with insulated double wall? I was just about to order Metal-Fab 6TGS48 pipe and accessories but realized I don't have a way to make it look nice coming out of the terracotta. I could use the flat
roof cone flashing
but don't think it would look correct. Any suggestions or does a different brand have what I need?
roof cone flashing
Are you planning on using class a chimney inside a masonry chimney?
Yes. That is what I would like to use instead of transitioning from one type of pipe to another if possible.
Can. You explain the system using class a inside a chimney really is not what it is designed for.
