Clean that Glass...
G-rott Posted By G-rott, Oct 19, 2006 at 11:32 PM
Thread Status:
  1. G-rott
    G-rott
    Member 2.
    NULL
    Jan 7, 2006
    165
    1
    Loc:
    Petoskey Michigan
    It's time to realy get the glass in the stove clean. Any tricks out there?
    The stove is room temprature and I'm ready to go.
    I do use the ash and newsprint trick when the stove is still warm and I'm trying to keep it clean, like when I stoke the fire in the morning. But know it's ready for a real scrub down.
    Garett
  2. BigV
    BigV
    Member 2.
    NULL
    Oct 1, 2006
    139
    15
    Loc:
    Akron, OH
    I use Windex, then follow-up with a razor style 3” scrapper to get the built up stuff off. Then use the Windex again and the window is clean as new.
  3. Corie
    Corie
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    2,430
    1
    Loc:
    Halifax, VA
    A lot of the commercial products work pretty well. I have the Rutland version and it doesn't do a bad job at all imo.
  4. wtyamamoto
    wtyamamoto
    New Member 2.
    NULL
    Jul 17, 2006
    41
    0
    Loc:
    Southern NH
    Rutland makes a cream cleaner that also has silicones in it. It works quite well to clean - better than the spray cleaners on built up muck. The silicone leaves a slick surface like if you just waxed your car. The slick surface helps make future cleanings a lot easier. I found it at HD.
  5. menchhofer
    menchhofer
    Member 2.
    NULL
    Jan 10, 2006
    24
    0
    Loc:
    Indiana
    I just buy some cheap oven cleaner ($1) a can and use it. Works well using newspaper to clean the glass. Been doing this way for years.
  6. Dunadan
    Dunadan
    New Member 2.
    NULL
    Oct 3, 2006
    184
    0
    Loc:
    Holland Patent, NY
    Robbie posted a recipe in the thread here. Since it was long thread, here's the key post -
    I tried this over the weekend and it worked perfectly. Took off the thin build-up with almost no effort and took off some real thick build-up with after a few applications.
    I'm too new to have tried anything else.
  7. Burn-1
    Burn-1
    Feeling the Heat 2.
    NULL
    Jul 13, 2006
    446
    1
    Loc:
    Lakes Region, NH
    This stuff works great. It's designed for ceramic glass
    Weiman Glass Cooktoop Cleaner
    I think we got it from Market Basket here in NH but Target has it too.
  8. Webwidow
    Webwidow
    Member 2.
    NULL
    Jun 3, 2006
    133
    0
    Loc:
    Western MA.
    In our shop we used and sold Speedy White to clean stove glass.It worked like a charm. Put away your razor blades, speedy white does the job.
    http://www.speedywhite.com/
  9. junksta
    junksta
    New Member 2.
    NULL
    Oct 13, 2006
    44
    0
    Loc:
    Pinedale, AZ Elev. 6400'
    I found that the cheap orange citrus cleaner you can get at dollar stores works good.
  10. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,561
    9,732
    Loc:
    Northern Virginia
    But Webwidow, I thought you hated the smell of smoke and creosote. How would you know how the glass cleaner works. Didn't ya dump that job on Craig?
  11. precaud
    precaud
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    2,305
    40
    Loc:
    Sunny New Mexico
    White vinegar works well. So does ammonia. Both are quite cheap.
  12. wg_bent
    wg_bent
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    2,248
    6
    Loc:
    Poughkeepsie, NY
    I use spray 9 Fireview dissolves the stuff and smells like windex.Really works great, but glass needs to be nothing more than warm. Mostly I just use water.
  13. Webwidow
    Webwidow
    Member 2.
    NULL
    Jun 3, 2006
    133
    0
    Loc:
    Western MA.
    Oh the famous "quicky" load.
    [/quote]But Webwidow, I thought you hated the smell of smoke and creosote. How would you know how the glass cleaner works. Didn't ya dump that job on Craig?[/quote]
    I only dislike the smell of smoke if the stove tender does not open the by-pass damper prior to loading. Hence the house becomes the chimney. You know how it goes..."but honey it was only one log, but honey I only needed to poke around a minute".
    I know some of you are guilty of this as well. It is known as the quicky load. hahaha
  14. Rhone
    Rhone
    Minister of Fire 2.
    NULL
    Nov 21, 2005
    825
    3
    I've tried the oven cleaner, vinegar, ash & newspaper, nothing worked like Rutland's Hearth & Grill Conditioning Glass and it's so cheap and makes the next cleaning much easier. It even works on the really thick black stuff. No matter what you try, it's going to take elbow grease but that polish sure works good.
    I went through half a bottle last year, it being $6.00 a bottle it doesn't make a lot of sense to bother with other products IMHO. They also make a product called "White Off", don't get that it's for gas appliances.
  15. Corey
    Corey
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    2,299
    157
    Loc:
    Midwest
    I have to put in a vote for "castrol super clean" and wipe down with newspaper. Spray it on, the crud melts right off. I don't usually have a problem during the hard burning days of winter. The glass keeps itself pretty clean. But during the lazy fires of autumn and spring, it tends to smoke up a bit.
    I also noticed a product mentioned earlier that contained silicone for easier second cleanings. I wonder if a product like Rain-X would provide similar protection? I feel an experiment coming on.
    Corey
  16. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,312
    5,964
    Loc:
    Northern IL
    I have to go with Rhonemas on this one. That stuff really works great. It is usually available at most stove shops and also hardware stores around here. Once every 2 weeks I clean the glass, even if it doesn't need it. I do have to admit, the glass on my stove stays pretty clean all by itself though.
  17. suematteva
    suematteva
    New Member 2.
    NULL
    May 25, 2006
    605
    0
    Loc:
    Rutland, VT//Southern Quebec
    white vinegar and water...almost wrote white wine...that too but down the gullet!
  18. Gibbonboy
    Gibbonboy
    New Member 2.
    NULL
    Oct 3, 2006
    267
    0
    Another vote for the Rutland cleaner, I only use it very occaisionally, my glass stays fairly clean, except in the corners.
  19. tradergordo
    tradergordo
    Minister of Fire 2.
    NULL
    May 31, 2006
    811
    3
    Loc:
    Phoenixville, PA
    Don't know if its the same, but I was wondering about the cheap ($1) orange goop hand cleaner stuff. I have some already (haven't tried it on stove). Seems perfect for the job though and its all natural, no chemicals, and smells good. I will try it tonight. Harbor Freight sells it.
    EDIT: It worked better than I could have imagined - took everything off with as little effort as possible. Much better than windex and a razor (I tried that the last time). The product I have is called "GOJO".
    p.s. Not sure if its good to use products with pumice though, some say it can scratch the glass (ceramic really). I did not notice any scratches though.
  20. Greg123
    Greg123
    New Member 2.
    NULL
    Jul 21, 2006
    196
    0
    Loc:
    WNY
    I use a wood stove glass cleaner from a company called imperial group. You spray it on the glass wait 2 min, and wipe it off with a damp cloth; it cleans the glass like new.
  21. G-rott
    G-rott
    Member 2.
    NULL
    Jan 7, 2006
    165
    1
    Loc:
    Petoskey Michigan
    Thanks for all the help, any other tips or tricks are welcome.
    Looks like it's time to get started.
    And yes it is the thick bottom and corners I'm about to attack.
    Garett
  22. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,605
    7,877
    Loc:
    South Puget Sound, WA
    Rutland. I got a bottle a year ago last August and it is still 95% full. It does help with soot build up on the glass and seems to take it off lickety split.
  23. cogger
    cogger
    Member 2.
    NULL
    Oct 10, 2006
    193
    0
    Yep. Just did mine a few min ago. Better when wet. Like wet sanding paint on a car.
  24. kkesler
    kkesler
    Member 2.
    NULL
    Jan 22, 2006
    33
    0
    Loc:
    Winder, Ga
    Ok. Wow. Like you I tried all kinds of stuff, the vinegar/ash, spray cleaners, etc. and nothing comes close this stuff. Took maybe a minute to get the door really clean.
    Thanks!
  25. senorFrog
    senorFrog
    New Member 2.
    NULL
    Aug 31, 2006
    285
    2
    I've been using Rutland WHITE-OFF. Works great. Glass clean in about two seconds.
    http://www.rutland.com/565/565.htm
    I'd like to try the Rutland HEARTH & GRILL CONDITIONING GLASS CLEANER for a comparison.
Thread Status:
