Greetings,
A mason is building a brick chimney for a wood burning Regency I2400 insert.
The manual says 11" clearance needed from sides of the insert to combustibles, but it does not say how far to brick.
This is an issue because the mason has laid brick right up against the side of the unit -- blocking 90% of that long open slot along the bottom. I understand that slot to be combustion air intake, and it must be open. He believes that the several square inches remaining open is sufficient, since the blower is the main thing providing air. (I think the blower is only for recirculating room air and never meets log.) Work has halted until this gets resolved.
How much clearance should there be above, behind, and to the side of the firebox? Only brick surrounds it.
Next issue. The part of the unit that fits into the cavity is 32" wide. The brick walls we installed start out at 42" and narrow to about 35" wide. I live in fear that we built the walls too narrow. Could we raise the unit up about 1" on four legs, to help air flow to the intake slots along the bottom of the sides? What would you use?
Thanks.
Thanks.
