Hi all,
So i have a CH2500 and the manual states that i need the clearance to combustibles to be 10.5 inches on the side and 20.inches to the back in a corner configuration. Here is the manual online http://www.usstove.com/image/manuals/Wood/2500.pdf
My question is I installed a heat shield using 1/2 cement board with slate tile and with the 1 inch air gap which allows a 50% reduction in clearance to combustibles but I heard that you can't 'double up on the clearance if stoves like the CH2500 already have a shield on the back and sides. is that true? If that is the case the heat shield is useless. The other issue is that if i do need to maintain the factory set clearance then I cannot use my two 45 degree elbows and instead need to use two 90 degree elbows in order to push out the stove from the heat shield which sucks for draft. The other question I have is there a recommended minimum vertical length from the stove to the 90 degree elbow to ensure the best draft through two 90 degree elbows?
thanks
AA
thanks
AA
