I've begun to do some demo on the house and this is what I've come to.
I'll put a better picture up of where I'm at now - all you see are studs and where the floor isn't patched yet. My 'plan' is to open the wall, obviously, and then somewhere, install a woodstove. A small woodstove. A Morso 7642 woodstove to be exact. Clearance to the rear is about 4" with double wall (I believe - will check again).
The stove has a rear or top flue. We want to use the rear and see as little stovepipe as possible. This means running a chimney in the wall or in a drywalled box somewhere. Based on what you see here, does anyone have any ideas?
I'll update again in a bit to show a little bit better photos with the mess cleaned up - and I'll show more angles.
Thanks for any help. It's beginning to get exciting.
278875_10150261930718390_596128389_7290596_2621589_o.jpg166.4 KB · Views: 374
272454_10150261931068390_596128389_7290600_449790_o.jpg143.5 KB · Views: 380
272844_10150268388388390_596128389_7344104_1234836_o.jpg155.7 KB · Views: 465
