craigslist treasure
Would have been nice if they had said if it was EPA rated! :)
Personally, I would prefer the blue/black finish like the Oslo. :)
Shari
I do not know if this type of a burner is a rare on the east coast but I see these all the time on my CL. It makes me wonder every time I see them, but the add is gone within a week or so.
Pretty clean burners. They burn so out of control and hot when the sides are glowing that they produce zip smoke. Just keep a foot of sand in the bottom to keep it from burning out and dropping a burning load in the floor.
cmonSTART said:
I bet you could make one heck of a smoker out of it.
You betcha. That would need a really big filing cabinet. And guy wires. And a ladder. And half a cow.
that tank heater has possibilities. it could have some pipes welded in it for a secondary burner. and on one side of the end with the door you could install a gas gun burner and the other side a oil gun burner.
yah yah that's what it could be, a multi fuel stove.
Whats next? Converting 1000 gallon propane tanks to wood stoves?
Sure take the trouble out of splitting and stacking..... and bucking.
it's possible but it would have to be a top loader and you'll need a crane to load it.
I use the same type set up for my maple syrup evaporator, except laying on its side and with a 30" x30" square section cut out of the top for the pan to sit on. It does throw the heat.
What are the hearth pad requirements and clearances??? Bet it would look good in the living room as it is glowing red.
No, those get made into OWBs. Go over to Arboristsite if you don't believe me.
You need a second tank on top, like the double barrel stoves. I bet you could sell a kit for it.
fbelec said:
I know a guy that put his on a chassis and made a dual pig roaster painted it pink and all
Whats next? Converting 1000 gallon SEPTIC tanks to wood stoves?[/quote]
Zap
These two have been on NYC Craig's List a couple times over the winter.
How many splits per gallon?
