Cub Cadet help
woodsman23 Posted By woodsman23, Sep 15, 2013 at 9:04 AM
Thread Status:
  1. woodsman23
    woodsman23
    Minister of Fire 2.
    NULL
    Aug 26, 2008
    1,352
    46
    Loc:
    western southern tier of NYS
    My 05 slt1554 has an issue with the deck belt popping off all the time, nothing is bent and still it just pops off while mowing, any ideas as to what is going on here.
  2. Jack Straw
    Jack Straw
    Minister of Fire 2.
    NULL
    Dec 22, 2008
    2,161
    1,329
    Loc:
    Schoharie County, N Y
    How old is the belt? Is it stretched out? Are all of the pullies spinning freely? Is it a timing type belt? A friend of mine had a Cub Cadet with a timing belt and he could not keep it on. A CC rep found another mower deck (regular V belt) and replaced it.
    PM Master Mechanic......he lives up to his name!;)
  3. woodsman23
    woodsman23
    Minister of Fire 2.
    NULL
    Aug 26, 2008
    1,352
    46
    Loc:
    Belt is 1 yr old and its the deck belt for the blades, everything spins as it should. There is nothing more aggravating than mowing and stopping to put the belt back on.
  4. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,500
    6,074
    Loc:
    Northern IL
    If one of the cords in the belt is broken, it can react that way. It may not even be visible to the eye. It allows for un-even loading from top to bottom of the belt and can cause it to jump off. Try replacing the belt. Even if that is not the cause - you have a spare hanging in the garage for when you need it.
  5. MasterMech
    MasterMech
    Guest 2.
    NULL
    When does it pop off? Randomly? Or when you shut down the deck? Start-up?
  6. daveswoodhauler
    daveswoodhauler
    Minister of Fire 2.
    NULL
    May 20, 2008
    1,847
    96
    Loc:
    Massachusetts
    And bearings bad on the pulley.....a little wobble perhaps? Had that on my Ariens and the blt would keep popping off after 3-4 minutes.
  7. woodsman23
    woodsman23
    Minister of Fire 2.
    NULL
    Aug 26, 2008
    1,352
    46
    Loc:
    It comes off when mowing mostly in taller grass.
  8. MasterMech
    MasterMech
    Guest 2.
    NULL
    Check the pulleys. If they are worn out, the spindle bearings have excessive play, the belt will slip and pop off under load. If the tensioner is binding or the spring is incorrect, same symptoms.
Thread Status:
