Cut the small tree?
thewoodlands
16,677
In The Woods
This dead tree is hung up on a small maple so I think if I cut the small maple it will come down, any thoughts?
zap
That looks a little scary zap. Can't you take your winch and pull it sideways? It looks like it would fall the right way if you cut the maple, but being that close to that much weight scares me. I have used a come-along on some like that. Now I have the Bobcat and I could just give it a push. Another option is cutting the big boy a couple of times from the bottom. Sometimes that is enough to get it moving. I assume you have tried the winch already since you have done that before.
I think I would use my pole saw with a long reach.
zap
Yep, be careful. I would try every "remote" option. Possibly even dropping another tree on the whole mess bringing all 3 down. I dont think cutting on the tree that the dead one is resting on sounds too good
Is your winch strong enough to pull the butt end around?
Its hard for me to see clearly. If I was going to cut the Maple I would not notch it. I would do a slow rip cut than get back when it starts to go. I don't like to work under hung trees so I would do back cuts on the dead tree. That's my eye from a distance hope it helps some
I think I'll put a tree saver (tow strap) around the dead tree then hook it to the winch and roll it off.
zap
wood spliter said:
That even sounds safer Zap!
It's close to the road so I'll have plenty of room to run the rhino.
zap
Good call Zap. Even better would be a tree saver+20' chain+ Rhino, and drive off in the opposite direction. Yank out the bottom a few feet, and it should go. Stay safe with that one.
Chain will be added, weather permitting it will come down Wednesday with pictures of course.
zap
good decision.
We will find out Wednesday, I might take the old green truck then I might pull it home.
zap
As long as its not a threat I'd go on to the next tree.
The road I use for the rhino & truck runs underneath the top of the dead tree so it has to come down.
zap
zap
I like that style. I have pulled some pretty big trunks for milling.
smokinjay said:
zap
The wife wants it down so we will go back tonight and take it down then buck it up, I'm going to test it with the moisture meter any guesses on what it will read?
zap
I will start the bidding at 18 percent top half and 24 on the butt.
Zap, even with a pole saw I rarely ever cut a tree that another was hung up in. I say rarely, because I have done it but it is a very rare case indeed. On that size tree I probably would not even consider it. I do like the truck idea and just bring it on home. Good luck with this one.
On numerous occasions I've had to cut the support tree to get the widowmaker leaner down. I've never enjoyed it in the least and I'd say strapping it nad giving the butt end a good yank is the best approach. Sucker can bounce when the energy from impact reaches the butt end though, so make sure you've got a good long leader for slack.
i would definitely be very nervous cutting the smaller tree that the dead one is leaning on, i would try another way, preferably using a rope and trying to winch it or use a come-along to get it moving.
