Dayton replacement motor
HEMI
465
connecticut
is this a good replacement or should i go to the dealer for the oem part
Distribution blower? Should be the exact one, assuming you have the correct part #. If your stove is brand newish, Harman switched OEM manufacturers. Not sure if the Dayton would still work, but my GUESS is yes.
If the dealer $ isn't too far off, it's always good to keep it local.
thank you......stove is 4 years old, the dealer is about $80-90 more thats why im asking input....are they fairly easy to install? i did one on an englander i had and that was easy
After the shield is off, two bolts for the motor and the wiring connectors. Clean your fines box while your there.
