Did I run stove too hot?
Michbrog23
59
Danville, KY
Just got a Osburn 950 installed, and noticed some discoloration on the bottom section of the door frame. I’m curious if I ran the stove too hot to cause this, and curious if the gasket is supposed to look like this?
15467568-6BC4-45F8-B3BF-E50147BBCBC8.jpeg AF8B1E49-C6F4-4262-B67A-933AEAEDA5FC.jpeg260B834B-37FB-4C60-87FE-0BEE6B3B9006.jpeg41CA3CA7-D5D0-487D-BC2A-03C0108E4073.jpegF1CFB692-3DE8-42EF-B47D-998EA8DC953B.jpeg
Looks like if anything you were running it low and slow.
I don’t see anything wrong with the gasket. I’m not an installer or chimney sweep though.
By looking at the glass it seems to be soot build up.
I was getting this after 1 or 2 fires and discovered I was closing the door to soon !
Do a little cleaning then try leaving your door ajar 2-3" until logs are burning good and hot before closing.
Looks ok to me. Soot on the back bricks tells me it was no where near too hot.
Reactions: oilcan1001
To be clear, we know the last burn did not finish hot. However, it's impossible to say what could have happened previously.
That said, it's not abnormal for the door sill to lose its black paint. Mine have all gone au naturale.
Looks like brown soot. Latch has lost its paint. Here is mine.
What does that soot indicate? Still waiting on a couple thermometers, just trying to figure how full to run this thing for optimum performance
A normal burning fire with dry wood will not leave soot in the firebox. It gets hot enough to burn it all off. Some near the . The door happens as the air wash air keeps the front door cooler. But on my Drolet I don’t get any on the door.
Optimum performance means measuring flue gas temps.
