Diy Storage Tank
mikes8500
1
Long Island, NY (Nassau)
I've got pleny of concrete block laying around, I was wondering if there were any pitfalls to using concrete block & mortar to make a 4' high wall butted up against the basement wall that I could then throw some insulation and a liner and use for hot water storage. I'd do rebar in every other core, and drill, grout it to the basment floor and fill the core solid with concrete. Figure I'd need 9'x30"x4' high to get approx 800gal
Mike
Dunno. I'm waiting for some success stories from other folks doing similar things. I'm a bit concerned about the force of the water pressure trying to pull it away from the existing wall. At the bottom, it's 2 pounds for every square inch. The pressure in the middle of the 9' section worries me a bit.
mikes8500 - That is the way I am building mine. It will be 4.5'x12'x4' to give me just over 1000 gal. once insulation etc. is subtracted. I am in the process of building it now, check out the link in my signature for updates and images. With threaded rod coming out of the walls into the block joint and vertical rebar out of the floor in the first hole I am fairly confident it won't pull away from the wall over time. I hope to be finished in the next couple of weeks, but success will probably need to be measured over a long period of time.
