I originally posted this in the VC thread:
I bought a new refractory box for my VC Winterwarm Small. When I removed the old box I saw that there is a secondary air probe (thermostat) sticking into the stove from the back. In order to get my new box in I would have to pierce a hole in it. I am reluctant to do that, as I don't even know if the thermostat still works. So, a few questions...
1.) Is there any way to test the thermostat to see if it still works? I can see the small 'door' that the thermostat would close if it was working.
2.) If I cut this thing off, does it even matter?
3.) If I were to cut it off, should I close off the small door and just adjust the air on my own with the main air control?
Before you suggest pulling the unit and replacing the thermostat from the back, I'm reluctant to disconnect the chimney to pull the unit out. I've looked into getting a tech over here to do that and it gets into costing more than this thing is worth...
Thanks for any help you guys can offer.
