I should have mentioned Garnification, who built his own, impressive-looking Garn-style boiler and has been very helpful and supportive of those interested in getting one of their own.
Sawyer said:Garn said:This thread is pure blasphemy! ;-P
Although mine is home grown I just love it! Its getting a workout right now. Last night was -5F with a WC @-25*F. Tonight, -10 to -15*F.
So far so good.
Oh, so the heat wave is south of us!
Garnification said:Sawyer said:Garn said:This thread is pure blasphemy! ;-P
So far so good.
Oh, I forgot about you northerners. Do you guys even turn your clocks back up there!?
Did you guys see that in the upper poll there is one voter that HATES his Garn!?! Must be a communist. After all they do like their crude cold war downdrafters. :red:
mike1234 said:I know this could be a highly volatile question, but be gentle, it's just a question.
Reading this commercial, er I mean thread, I just have to ask, how can a boiler that cost at least (as far as I have been able to tell from your posts) 15,000 to buy and install, (add 15,000 more if you have to build the shed) be something that saves you money? Even if you use less wood than I do by 1/2, it would take about 8 years to pay it off. Let say I pay my wood furnace off in 2, then I am pocketing that money, or buying a cool new chain saw, or a new splitter, or ..., for the 6 years you are still paying off the garn.
I do understand that you might just prefer the boiler over the furnace as a preference. But do you all have the $$ worked out so that what I said above is not the case? Again be gentle, it's just a question, and I am not questioning your religious beliefs.
If you are faithful in testing and treating the Garn’s water does either system have an advantage regarding longevity due to the pressurized vs. open system? Are open systems only more susceptible to corrosion when they aren’t properly maintained? Why do the Garn open systems seem to last so much longer than other open systems I’ve seen?
Do the Tarm/Eko systems blow some smoke in your face when you open the door?
With a Tarm/Eko system with a pressurized storage tank which is likely to go bad first, the storage or the boiler? What is a typical lifespan of one of these systems? I’ve heard of lots of 20+ year Garns on the field working great. I’ve heard the Tarms are long lasting but I don’t know many specifics.
Are there any major efficiency differences between a Garn and a Tarm type system?
[will have low BTU requirements]...in my mind it [Garn] just means shorter and less frequent burns. Am I incorrect in that thinking? Or are there negatives I should be considering?
ThisWarmHouse said:1. The Garn's water needs to be periodically tested/treated and a pressurized system doesn't need to be. If you are faithful in testing and treating the Garn's water does either system have an advantage regarding longevity due to the pressurized vs. open system? Are open systems only more susceptible to corrosion when they aren't properly maintained? Why do the Garn open systems seem to last so much longer than other open systems I've seen?
ThisWarmHouse said:2. Do the Tarm/Eko systems blow some smoke in your face when you open the door? One of the things I like about the Garn is the way the blower system is designed to not allow the smoke and flames to come out of the door when you open it. I have never experienced a Tarm/Eko system yet. Feedback?
ThisWarmHouse said:3. With a Tarm/Eko system with a pressurized storage tank which is likely to go bad first, the storage or the boiler? What is a typical lifespan of one of these systems? I've heard of lots of 20+ year Garns on the field working great. I've heard the Tarms are long lasting but I don't know many specifics.
ThisWarmHouse said:4. Are there any major efficiency differences between a Garn and a Tarm type system?
ThisWarmHouse said:5. I plan on building a monolithic dome home (super efficient) so I will have really low BTU requirements but with well insulated BTU storage I'm not really concerned with oversizing, in my mind it just means shorter and less frequent burns. Am I incorrect in that thinking? Or are there negatives I should be considering?
ThisWarmHouse said:Anyone here had hands on experience with both? What are you impressions of both types of systems? Plus and negatives for each please.
The boiler size in a storage situation is not related to the heat load - it is related to the tank size.
So, the Garn is the lowest among those, in combustion efficiency
Let’s talk about this 95 - 97% efficiency rating.
