    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. gman1001 New Member
    Sales
    I would like a bit more clearence from the wall to my Jotul 3td. Currently my stove is setup as follows.
    Section 1: Top vent 4' straight up
    Section 2: 90 degree elbow
    Section 3: 6 in long double ended connector pipe.
    Section 4: Through Wall connector to masonry chimney.
    All pipe is single wall 6"
    I've shopped like crazy for a double ended (Male/Male?) crimped piece of pipe that is longer than 6". Can't find any.
    I was going to go to my local metal shop and ask the guys if they have a die that can work on a piece of my straight pipe. But thought I'd ask here first.
    Thanks!
    G-
    Norwalk CT. Sunny 55 Degrees today. Why did I work so hard chopping all of this wood.....
    #1
    Helpful Sponsor Ads!
  2. carpniels Minister of Fire
    Rome, NY, USA
    Sorry G man,
    I have never seen a larger piece than 6" long. I don't think it exist. Why not just add a 12" piece of regular stove pipe to you 6" (section 3)? Cheap and you do not need your fancy piece of double crimped pipe. Moreover, you can cut it too size to whatever length you need. Problem solved.
    Carpniels
  3. gman1001 New Member
    Sales
    True true, that is a very good solution and prob. what I'll end up doing.
    I was kinda wondering if there was something out there I was just .... missing...
    Thanks for the help!
    G -
  4. elkimmeg Banned
    got the crimper here and piece here What do you need? I can make any length you need with both ends crimped figure 1.25" overlap ing the crimps
  5. zogboy New Member
    CNY
    You can by a crimp tool at the local hardware for a few bucks
    the one I have looks like a pair of vice grips with needle nose v noch jaws
    I bet you could do it with needle nose pliers if you try.
    Yes your local sheet metal shop will have a tool that crimps as well as make a shoulder stop.
Thread Status:
