TreePointer said:I saw that a little bit ago.
SpeeCo just came out with their version, too!
SpeedPro Kinetic Log Splitter
velvetfoot said:The SpeedPro supposedly goes vertical too?
How does that work out?
thinkxingu said:I'm not sold. I watched those videos--though you can tell they're faster, the time trials/comparisons are clearly not run for maximum speed for each machine. Those guys were using the full throw on the hydraulic splitters every time--I barely use half.
S
peterc38 said:True, plus they have a young buck running the SS clone and the guy running the hydraulic splitter looks like he is about 90.
Pineburner said:The issue i have with all these kinetic splitters is your chasing the wood off the oposite end of where your working, bending over way more than you should have to, and that makes them slower.
MasterMech said:I'm not so sure about the safety of kinetic splitters either. Is there a way to stop the ram mid-cycle? At least with a hydraulic you have some room for Oh S*&^ moments. I'd be double wary of running one with a partner.
CountryBoy19 said:peterc38 said:True, plus they have a young buck running the SS clone and the guy running the hydraulic splitter looks like he is about 90.
You must have missed the part where they switch operators mid-way through to rule that out.
