Draft and temperature
dmmoss51
355
Michigan
So wanted to defer something I think I noticed so some of the experts here.
I'm well aware that during.higher outdoor temperatures it can be hard to get a good draft because you don't have the temperature difference needed.
Is the opposite true? As it gets colder does the draft het stronger?
My reasoning is the last couple nights have gotten down into teens and I feel like I'm burning through wood faster even.with same air settings and same wood.
Draft sucking more air through same opening would make sense and I can slow it down by adjusting the air and damper.
So am I on the right track or off in left field?
Thanks
it is true about the draft in the cold. alot of troublesome stoves work great when it's cold out. if your having trouble just go by your stove thermometer.
Yes, it's certainly true. If you had an ideal flue (one without any back-pressure) and a stove that created the same temperature and composition of exhaust, the change in draft would be inversely proportional to the temperature.
Another thing that might be affecting your stove in this latest cold snap is the wind. I don't know what's going on in Michigan, but up here in Maine we've been getting a lot of wind as the cold front moves in. Wind gusts up to 40 mph last night and the gusts were every 30 to 60 seconds. This will cause a strong venturi effect at the top of your chimney and increase the draft considerably in short bursts. This can really eat through wood.
I live on the edge of a lake and have a 35+ foot chimney. I had to put in a barometric damper to calm things down. Otherwise my stove runs poorly and very erratically. Last night it was swinging open and closed like the bathroom door at an irish pub.
Well,
Time to walk the dog and stock the stove.
--joe
Different loads of wood will burn very differently also. Going from a load to oak to a load of soft maple will give you a much shorter burn time. This could contribute very easily to stacks of firewood that disappear.
Matt
It's a lot like playing an instrument, or like playing a different instrument every time.
Matt
Thanks Matt, note in the OP it's the same wood just burning faster.
So sounds like I am on track with the increased draft at the colder (an windier) conditions.
Looks the the main thing I am able to do is get the supply air down even lower when it's cold out. Also I experimented with slowly closing my flue damper to about 50% and these seemed to slow down the wood consumption without any adverse effects.
dmmoss, are you still burning with the air control full open?
edit: Scratch that... had you mixed up with member ApalachianStan.
