I've been told to watch out and not drive over a septic tank or leach field. No prob. I have a couple good sized oak trees to drop, however, and they'd really like to land there. Any issues?
Thanks. What about the leach field?
The leach field pipes should be within a foot of the surface for the evaporation to work. I would spread some small limbs over the area to displace the load when it hits. Just be aware that often when a tree hits the ground, limbs break off and the stubs penetrate the ground.
"The leach field pipes should be within a foot of the surface for the evaporation to work. "
A common misconcpetion. In all but the most extreme cases of unconventional systems the effluent is designed to soak in and go down into the earth. That is, NOT evaporation but infiltration into the soil. The earth above the laterals must not be compacted since it is very important that oxygen be able to travel into the soil to provide the aerobic bacteria with life giving oxygen. .
I drop trees where i want them to drop, not where they want to drop.
I would not drop one on septic tank or leach field.
Sounds like the tree needs to be close trimmed of all limbs first. Then taken down in sections to avoid impact. May sound like a pita, but what would damaging the septic system sound (or smell) like?
