Well after looking a while for a used or new airtight qboxstove design stove (i like loading this way, but i guess I'm in minority) i bought this stove and getting ready fo install. I only need the interior pipe because the 6" exterior pioe is already in place and good.
I have my collar and 2 sections of duravent double wall adjustable pipe to connect to my ceiling box.
Question, the stove is "airtight" and has air control but should I still install a damper just above the collar? Do any good or just more to go wrong? Any benefits?
Also, I've seen the heat reclaimer boxes go for $100 to $300, are they worth it? Is there an as-good or better way that is less costly? On my upstairs stove i have chimney pipe with a oscilating fan and ceiling fan only, and i don't know if i should try to capture more heat on this new stove doanstairs or just keep it straight pipe.
I know i don't want anything that requires electricity to have the pipe vent right, in case of power outage. If i install anything in the chimney pipe it must be passive and/or work fine if power is out too.
Thanks!
Thanks!
