How do you connect the Dwyer hose to the small pipe which goes in the stove pipe?? I have been just pushing the rubber hose onto the copper pipe, but once it heats up it just falls off. How do you connect yours?
I have 4 feet of copper tubing attached to the stove pipe. Then about 12 inches of the rubber tubing connected to the manometer. I connect the copper to rubber by using a piece of shrink wrap tubing. Butt the two ends together and heat the shrink wrap to seal. Works just fine.
Like I said above, my current copper tube is about 6", which works fine, but I wouldn't want it any shorter, especially with an appliance that runs higher flue temps than the Kuumas do...I rarely see over 400* internal temps...290-375* is where its at most of the time.
Thanks for the suggestions guys. My copper two hose connection is about a foot from the stove pipe but it still seems to fall off. I like the shrink wrap idea, and will try that first. Cheers.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
