Control board was replaced ,still getting a E2 error after lights on display stop blinking what do blinking lights mean. Ashley App5660 L
So that tells us that it is most likely not a vacuum problem. Next thing to check is Molex plugs and wiring. Inspect 4 pin connection pin 1 and 2 and the blue and gray wires from the plug all the way to air switch. Inspect the 6 pin connection pin 1 and 4 and white and green wires from the plug to the exhaust blower. My best guess is that there is a short in the wiring from board to exhaust blower or short in air switch wiring. You could try applying power to unplugged 6 pin plug at pin 1 and pin 4 that would check the wiring from board to blowerjumping the vaccuum switch had no effect, still no power to exoust blower motor
Yes that is backwards according to diagram.Ok ,dumb question time is it possible that I put the white and black wires on back on wrong, my white wire is on ACL black is on N ,I don't have a picture of this ,lol.
