It spun it's last time and expired at 5:25pm ET. Services will be held Tuesday morning by the garbage can.
BrotherBart said:
BeGreen said:Did the fan get overheated at some point or has it always been operated in the correct temp range (400-650°F) ?
BrotherBart said:The one in the amazon link is a cooler. The one on eBay is a generator.
Just sayin...
Edit: Just checked. They swing both ways.
tlingit said:Sorry about your ecofan. We keep two of them on the stove, it makes it took likes its going to take off and amuses me. Don't know how much air they move, but the image of my stove going off for an adventure makes me smile.
BrowningBAR said:BrotherBart said:
Neat. I didn't know I had that option. The little guy will be rebuilt. We will make him better!
stoveguy2esw said:you guys got me thinking, i might play around with a "teg" powered pellet stove, maybe a battery onboard and teg recharge off exhaust heat to hold the battery at a charged level. would be pretty cool to have a self powered pellet stove, im gonna have to play with that idea some
Sisu said:Ecofan, a woodstove fan. A fan barely alive.
Gentlemen, we can rebuild him. We have the technology. We have the capability to build the world's first bionic wood stove fan. Ecofan will be that fan. Better than he was before. Better, stronger, faster.
BeGreen said:stoveguy2esw said:you guys got me thinking, i might play around with a "teg" powered pellet stove, maybe a battery onboard and teg recharge off exhaust heat to hold the battery at a charged level. would be pretty cool to have a self powered pellet stove, im gonna have to play with that idea some
Welcome back Mike! Haven't seen you for a while.
stoveguy2esw said:you guys got me thinking , i might play around with a "teg" powered pellet stove, maybe a battery onboard and teg recharge off exhaust heat to hold the battery at a charged level. would be pretty cool to have a self powered pellet stove, im gonna have to play with that idea some
fossil said:stoveguy2esw said:you guys got me thinking , i might play around with a "teg" powered pellet stove, maybe a battery onboard and teg recharge off exhaust heat to hold the battery at a charged level. would be pretty cool to have a self powered pellet stove, im gonna have to play with that idea some
Brilliant. It would (if feasible/doable) eliminate the single most frequently mentioned drawback to pellet stoves...no heat when the power goes out. Nice to "see" you, Mike. Rick
stoveguy2esw said:fossil said:stoveguy2esw said:you guys got me thinking , i might play around with a "teg" powered pellet stove, maybe a battery onboard and teg recharge off exhaust heat to hold the battery at a charged level. would be pretty cool to have a self powered pellet stove, im gonna have to play with that idea some
thats kinda the idea's birth, i have to research power needs and see if it can be done effectively. obviously would want to keep costs down to make it practical gonna need to look at DC motors (all we currently use are AC , as well as a simple control system. its just an idea at this time but im grinding on it when i have timwe to think about it. if i can run everything off a 12 volt battery like a lawn motor sized one (aproved for indoors is gonna be an issue as well but im sure they are availible) then rack up a few of these teg generators to soak heat from the exhaust to constantly top off the battery when in use im thinking i can come up with a self sustaining power source generated by the stove itself. maybe come up with a connection to tie into PV as well my want is to make this thing not have to use any house power at all. i think i can do it but i gotta talk the boss into letting me spend some money on somthing completely new to us in order to make it happen
