Efficient use of wood
Pete Clark
7
S.E. Ohio
I'm feeding a Seton 100 with 500 gallons of storage. I don't have a way to weigh my wood so I hope someone can answer my question. Is it more efficient to build storage temps to max of 175-180 and let fire die until temp is around 140 or continue to feed small amounts and keep storage in the 150-160 range? We are experiencing colder season and I seem to be using more wood than last year. Any help would be appreciated.
Generally - feed to keep storage hot enough for your load & demand needs while avoiding idling.
Both idling, and trying to keep storage hotter than needed, are efficiency hits.
I've found that only heating my tank as high as I need to make it through to
my next burn is more efficient. Less standby losses from tank.
Is your storage inside?
Yes it is in the insulated boiler house. It's a 500 gallon propane tank with 12" of fiberglass insulation all around it so temp drop is minimal. Boiler house is about 75 ft from house and has about a 5 degree drop when there's a load. It's a pressurized system
I will drive up my tank to 175ish when it's brutal cold out and need the btu's. But generally I push it to the 160/65 range. pushing it to 175/180 seems to take a bit more wood driving it up to the top vs 165.
Since your storage is in the outside boiler house and not in your home I'd recommend not heating the tank any more than you need. What insulation do you have on your underground lines? 5 deg. drop in temp seems a little much. Wet ground?
I've only been using my system for a little over 2 years so I'm still a newbee. how long u been running your system?
Underground piping is 1" ThermoPex with the storage is approx 4' higher than house entrance and no trace of moisture anywhere. My gauges are not the best or in the best locations so that temp is questionable. This is the second season for me as well.
I've got a short section of Thermopex which part of it is exposed in my garage. You can put your hand on it and feel no warmth. Pretty good stuff i think.
