It will be easier to keep the nose on the ground if you hang the batteries off the front bumper...
Delta-T said:why would you have to get up...clearly your chair has caterpillar traction.....but i'm missing the cup holder, you may spill your beer.....maybe it is best to have the remote stop....what a dilemma.
Jags said:Update:
First test with young uns'. Test is successful. I made a foot pedal switch for both sides to assure a straddled position of the driver as well as a palm switch (think emergency switch on industrial machinery) on the back fender for adults that may need to shut it down fast.
I have also built a small trailer that the youngest simply loves to ride in (2). After a couple of more sessions with the oldest (3) he will be a pro at operation.
1st gear speed is almost perfect, but 2nd and 3rd are too much for the little ones at this time. I plan on blocking those out. The batteries last longer than I do.
fishingpol said:Great project Jags. I am a tinkerer but on a small scale level. Your thoughts on safety are most impressive while allowing fun.
I have two ideas for you:
1.) How about a clip on lanyard kill switch like on boats and jet ski's? Make the lanyard short so that if the operator dismounts, the tractor will loose power.
2.) Under the accelerator pedal, drill a small hole near the toe end through the deck. Take a small piece of threaded rod and feed up from below into the hole. Put a lock nut on the rod above and from below. Adjust the height of the rod to the speed you want. It is a kind of limiter. The pedal can only go down as low as the height of the rod that sticks up through the deck under the pedal.
Dune said:Good work Jags. Ready for a Volts wagon or a Ford Ranger conversion now?
Jags said:Dune said:Good work Jags. Ready for a Volts wagon or a Ford Ranger conversion now?
Actually if I had time/money to do it, I would love to do a 4 cyl diesel conversion of a Dakota. There is a commercial 4 banger that is used in some of the van/trucks like bread trucks that are a small version of the 6 cyl diesel that was installed in the full size dodge. That makes factory parts, to some extent, exist. People that have done that conversion are running around with VERY capable little pickups that are pulling 30+ mpg, and can still tow a decent load.
Dune said:Yeah, I was thinking a dakota might make a decent electric conversion...I like that the cab is wider than the standard minis, I am not lightweight and both of my sons are big guys too. Real tight fit with the three of us in a toyota or an s-10.
KarlP said:Dune said:Yeah, I was thinking a dakota might make a decent electric conversion...I like that the cab is wider than the standard minis, I am not lightweight and both of my sons are big guys too. Real tight fit with the three of us in a toyota or an s-10.
The Dakota is less than an inch wider in the front and less than an inch narrower in the rear than the Tacoma. I know the older Toyotas were narrower, but so where the older Dakotas. Might want to think of a fullsize for three big guys across.
lukem said:The mushroom switch on the back is nice too. Good thinking.
