- Dec 6, 2008
- 134
Light is on.
Getting a slight hesitation or skip when accelerating. Any idea's?
05 Toyota 65-75000 miles
most common is 02 sensorSouth of Boston said:Light is on.
CZARCAR said:would a faulty O2 sensor make it skip on acceleration?smokinj said:most common is 02 sensorSouth of Boston said:Light is on.
yes it can! Spark plugs are very rarely the proplem but spark plug wire off maybe? (still my bet 02)if never replace it before it will make them run bad and use more gas witch pops the check eng. light Any of the parts stores will check it for free (if the check engine lights starts flashing then you have big problems)CZARCAR said:would a faulty O2 sensor make it skip on acceleration?smokinj said:most common is 02 sensorSouth of Boston said:Light is on.
theCase said:I've got a '06 'rolla witth 65K miles that had a similar problem, I was pulling a P0171 code which indicated the MAF sensor. Took it in to the dealer and they diagnosed it as a bad intake manifold gasket. The also replaced the ECU that is under warranty for 80K miles. That was 4,000 miles ago I haven't had a problem since. Out of pocket cost was around $200 and that included an oil change.
Bottom line, Get that code read: Take it to AutoZone or somewhere like that, they'll pull the code for free. You really don't have a clue as to what may be causing this until then.
As for me I have a ScanGauge hooked up to my OBD-II port that allows me to monitor the engine (mileage, water temp, RPMs, etc), plus read and reset codes. Well worth the price (in my opinion).
theCase said:...
stop drop & roll said:Ah, a post right down my alley. If you could, find out what code you have and we'll take it from there. I am a Toyota technician of 19 years. Most likely as already been stated, it probably is a p0171(fuel system too lean) or a air-fuel ratio sensor/ o2 sensor code. Yes, there is a service bulletin for intake manifold gskts and ecu issues, but with your mileage its most likely a dirty MAF sensor or A-F/ O2 sensor fault. There I go rambling on, lets get a code first.
South of Boston said:stop drop & roll said:Ah, a post right down my alley. If you could, find out what code you have and we'll take it from there. I am a Toyota technician of 19 years. Most likely as already been stated, it probably is a p0171(fuel system too lean) or a air-fuel ratio sensor/ o2 sensor code. Yes, there is a service bulletin for intake manifold gskts and ecu issues, but with your mileage its most likely a dirty MAF sensor or A-F/ O2 sensor fault. There I go rambling on, lets get a code first.
Great news! Got the wife heading to Auto Zone tomorrow. NETS fan? GOt the Celts tonight
stop drop & roll said:Okay, here it is. Your car needs a engine control module (ecm) to correct this problem. The bad news is, it is just out of warranty by mileage. Ecm's are covered for 8 years, 80,000 miles. If you look in your owners manual, there is a (800) number you can call to plea your case and they are pretty good at helping people out. Since you are close in mileage, they might do a, buy the part and you pay the labor kind of thing. Ecm's are expensive (1000.00 +) but labor should be cheap, the ecm is mounted right under the glove box. Maybee you have an extended warranty policy?
There is a service bulletin for this condition that states... Some 2005-2007 model year Corolla and Matrix vehicles equipped with an automatic transaxle may exhibit a harsh shift condition and a M.I.L. "on" with dtc p2716 stored. Improvements have been made to the engine control module (ecm) to reduce the possibillity of this condition occurring.
So, first thing I would do is bring it to your nearest dealer for diagnosis and at least you will have a heads-up on whats going on. If they are a reputable dealer, they will take care of you. If not, call the (800) number. Good luck, Lyle
