Call me crazy, but the install appears to be too easy in theory. (especially after hours of research on the web)
Ok, I have my damper out and it is wide enough to accomodate the 6" SS flex liner. I have a straight shot up/down the chimney with no obstructions.
Is it really as simple as feeding the liner down the chimney and attaching it to the stove?? I understand about installing a top plate, rain cap and damper block off but that is a few screws and cuts in some metal. Am I missing something?
Chimney is around 20', interior masonry chimney.
After the install, a few break in fires then good to go? Is all my research overcomplicating the process in my head maybe??
Final questions
I am planning on putting a stove top thermometer. Should I put on up on the chimney? where would I place this if the stove is going to be inside my fireplace opening? Not much room on the liner before the block off plate??
Thanks again
Final questions
Thanks again
