Hello - I'm new here but have had my stove for 3 seasons.
I was having feed problems and I found a binding problem which I straightened out. I also took the motor off the bottom aguer which runs continuously and swapped it to the top where it runs intermittently figureing that the top motor should be in the best shape of the two because it doesnt work as much. Did I say that right? Anyway, I swapped the motors around from their original positions.
Now the stove doesnt put out as much heat as it did before I made the change. Previously, with the stove set on 6, it would burn about 2 bags of pellets in 24 hours and keep the basement about 80 degrees. Now set on 9 it only burns about 3/4 of one bag and the basement is just under 70.
The settings in the three bottom buttons are 6, 4, and 1.
Any ideas?
Any ideas?
