Enviro M55 Magnahelic Readings
JJD_ENVIRO
3
Canada
I used a Magnahelic gauge so I could set the damper correctly on my Enviro M55 pellet stove. The manual stated that it should be between 0.15 and 0.17 on high. When adjusting the damper, the lowest I can get the reading is .21. Does this indicate something else is wrong with the stove? Is it getting to much air from somewhere else or is this even a concern?
To get this lowest reading I have the slide damper pushed all the way in.
Where is the Combustion trim set?
I am taking the reading from the 1/8" hole located on the right of the ash tray. Manual states that is where it should be taken from.
Combustion trim is set at 3 (middle setting). I played around with the trim (both up and down) and it didn't seem to make any difference on the gauge.
