Error code issue please help
Arcticcatgod01
1
Mannsville ny
I have a bosca spirit 500 pellet stove my pipe was gunked up so I took it apart to clean it. Now it turns on runs for 15 sec and shuts off. Error code says exhaust issue !! Someone help now what I have made sure everything is tight and no leaks but still getting same code what next
The usual - are you sure the vent isn't plugged by ash you knocked down? Is the exhaust blower running? What is the exact error the stove comes up with? Is there a clogged screen on the vent pipe? It sounds like you have an airflow problem, and the common faults I just mentioned.
Reactions: Arcticcatgod01
My first thought is what Lake Girl said. There are passages inside the stove that could be clogged or the blower blades for that matter. Do you have a routine schedule for cleaning your stove ?
The two "tear drops" on the back of the firebox wall should be able to swing out of the way when slightly loosened ... if you can get a brush in there that's better. Some use a bottle brush; I use a dryer lint brush but my stove is tall. I have a hose attached to my shop vac with drywall bag that I use to snake into the internal exhaust pathways. If you remove the exhaust blower, make sure you have a gasket if needed.
Keep us posted...
