Excessive Ash - Not your typical issue
RayRay1
2
06482
First time posting and I know there are many posts regarding ash build-up but mine seems to be different.
Pellet Insert: Quadrafire Santa Fe.
Issue: Excessive ash buildup on glass. I cannot see inside the stove after 12-18 hours of use. I have to clean the window every morning.
Maintenance:
Unit is professionally cleaned once a year by the dealer (including chimney liner)
I clean the ash pot daily (service tech said it's immaculate).
Remove ash daily
I perform weekly maintenance (remove baffle and the faux brick walls on each side [sorry not sure what they're called] and clean out ash etc.)
Pellets:
I do not burn box store pellets.
I usually burn Energex. The dealer suggested I burn 5 bags of Hamers Hot Ones to see if there is a difference. No difference - same issue.
Dealer called Quadrafire and suggested I check the Tadpole Gasket: the gasket new this year and the round portion is on the "hinge side" of the door.
Any thoughts would be greatly appreciated!
Thanks!
Maintenance:
Remove ash daily
Pellets:
Thanks!
The AirWash on the door is what will keep the glass from quickly fogging-up. On my SantaFe the AirWash is at the bottom of the door. There is no gasket seal there.
That I understand..there is no gasket on the bottom....is there a way to see if the airways is defective..ie take it out for inspection? Or is it part of the frame?
