Factors to consider when choosing, installing woodburning insert in existing fireplace?
jcnnnghm
1
Central IL
I'm brand new to the forums and the whole Hearth.com site and a little overwhelmed right now with all the info here.
But to be brief, I'm considering installing a woodburning insert in an existing masonry fireplace in a 1920's bungalow. The existing fireplace has worked well for the 10 years we've had the house and the chimney is on an exterior wall. The fireplace opening now seems a little small for the inserts I'm seeing online. We live in Central IL.
-can i have some of the existing fireplace opening removed/modified to fit a too-large insert?
-do i need to have my existing flue lined with a metal liner?
-ballpark cost for what i'm looking at with insert, installation and liner?
Please just point me to existing material on this site. Thanks for your help!
Jeff c
Check the size of the flue tile in the chimney (the ID). Chances are that you will have to reline the entire chimney for safest and best operation.
As to modification, that is difficult. Can you let us know the fireplace dimensions? Also, have you considered a stove on the hearth (in front) or some of the inserts that stick out a bit? On some inserts you can move the panels back a small amount, thereby reducing the amount of interior fireplace space needed.
In addition to Craig's questions it would be good to know what size is the room that the fireplace is in? What size is the house? And how do you intend to use the insert, 24/7 or evenings and weekends?
Most manuals should specifically state NOT to modify the existing fireplace in any way. We had one customer who really wanted the big beast 5100i so they actually paid for the masonry fireplace to be rebuilt larger. He busted out the old material inside and a mason came in and rebuilt it to code. Basically the wood insert should only be installed into a safe and functional wood fireplace.
Probably... also should be insulated if possible.
3-5k depending on the stove and options chosen
