Hello
Common problem here, the new gate settled. The hinges can reset the height but what about the latch? The gate is not latching by itself anymore and the 2 screws are slowly stripping from the latch striker! Yesterday they finally have way and the light vinyl door (just like the song) is blowing in the wind!
This is the original latch with the ridged 2 bolt lever that must be in the same place or it will not work!
https://m.lowes.com/pd/BOERBOEL-4-1-2-in-Stainless-Steel-Gate-Latch/50290457
After a lot of research, I found this!
Auto self adjusting after a sag up to 1/2”
https://m.lowes.com/pd/National-Hardware-4-1-8-in-Black-Gate-Latch/50414122
Now the problem is that the wire to the other side is stiff and preventing the fence from latching by itself when the gate hinge springs close it?
I tried changing the wire to twine and it works more often but not every time when I take the wire or string off!!
Any suggestions?
My guess is the hole is too close to the top of the latch and maybe if was higher up, that may help?
Or even more flexible nylon rope? Or small chain?
Pic 1-2 Original latch with rigid 2 screw striker
Pic 3 New self adjusting latch
Pic 4-7 shows latch self adjusting
Pic 8 - Shows twine that helps latching but still not 100%
Any suggestions?
