well fired up the eko 25 for the first time this year tonight. new gasket is installed and stopping the stink which is good god I love not hearing the furnace not kicking in when it is 30 degrees outside!
got down to 30 last night brrrrrr but the eko kept us toasty! 35 tonight cnace of snow in higher elevations so the eko is still cookin! went to a apple festival this weekend and there was a wood stove/furnace sales person there so I figured I would check it out. asked him about a gasifier and he said he did not know too much about them but he heard they didnt work etc and I should get a wood furnace they are better yadda yadda yadda. kinda smirked and said thanks but no thanks.
I've got my Econoburn running for the first time this fall this evening; I'd been getting by with no heat, but that was getting old. 2 hours after lighting the fire, the entire house is filled with cozy warmth.
Did you have to really bend on that new gasket to get it to seal properly? Mine is in but I haven't burned yet. I had to back the hinges wayyyyy out to get the door to latch. I'm leaving it closed for a few days hoping I can turn the hinges back in a little before my first fire.
Did you use RTV or anything where the ends of the gasket meet?
installng the new gasket took me about an hour or so I was being very carful cleaned out all the old gasket and gasket cement then put the new one in be sure not to twist it. If you do there will be creases where smoke will sneak out of the seal. I did not need to cut an eccess off of the gasket I just worked in in so the ehole thing fit. I then used automotive red silicone on the ends basically wedged the plastic spout thing on the tube in and sqeezed a bunch in. then I put som in each corner I figured that would be the most likely spot to have a leak due to the 90 degree turn. I ended up turning the hinges out 2 turns and putting som weight into closing the door several times the more times it opens and closes the better the seal works in and the easier it closes. I figure I will need to turn the hinges back in 1 turn in a week or so. Knock on wood no leaks yet and everything is going great. Highly recomend the new seal to any of you eko guys probably the best 36 bucks I have spent in a while.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
