Flame Retardant Insulation
reed102 Posted By reed102, Oct 12, 2006 at 3:05 AM
Thread Status:
  1. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    Looks like blocking off the damper around the liner with flame retardant insulation is about the only way I will be able to seal things. A metal plate will be a nightmare and well beyond my skill level. What are some of the brands of flame retardant insulation I should try to find? Thanks
  2. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Take the measurements to a sheet metal shop and they will make the thing for less than non-combusible insulation will cost you. Besides, it appears the stuff ain't real easy to find and won't do the job real well.
    Use the measurement method in Craigs post in the Wiki for making a block-off plate.
  3. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    The big problem is that the sides and back wall are not flat. It corrugated like the side of a grain bin. It is a heat-a-lator clone, a large metal box. I thought getting the metal cut to match the sides and back wall would be much more expensive than stuffing the insulation. I'll check further on having the metal made. Thanks
  4. elkimmeg
    elkimmeg
    Guest 2.
    NULL
    Hint the block off plate does not have to be one piece ypu could use a colple of pieces and use a draft stop sealant
    in a caulking tube key here is ASTM 136 requirement don't worry its sold at home crapo
    ASTM 136 requirement meant it will withstand temps up to 1200 degrees the BOSS brand has been tested to
    3000 degrees. the Dap version tested to 2000 degrees You can use RTV around the premeter but not to seal the pipe and plate space. I found that out when we actually had a fire causd by Rtv igniting ignition point the RTV incontact with the liner
  5. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    I reread the directions in Craig's post and looked farther up into the actual damper and the sides are flat and shouldn't be much of a problem to have metal cut and bent to fit. And, you are correct fire-retardant insulation is about impossible to find. Thanks
  6. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    Made a cardboard template of the blockoff plate and will be taking it to a metal shop. What thickness, gauge and/or type of steel should I tell them to make it out of? Thanks
  7. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    I don't see any reason why anything from 24 gauge galvanized on up to thicker steels wouldn't get the job done. All it has to do is not let air through and be non-combustible. It won't be exposed to flames or flue gases.
Thread Status:
