Flooring question
Morgan Posted By Morgan, Mar 17, 2013 at 7:22 PM
  1. Morgan
    Morgan
    Member 2.
    NULL
    Apr 24, 2010
    111
    16
    Loc:
    PEI, Canada
    Going to be laying some laminate flooring in a rec room I have been slowly working on, the room is going to be approx 15'x27' What way is recommended that I run the flooring? Should the long side of the laminate pieces run with the length of the room or the width? Was just standing down there thinking about it and after 15 mins or so I am still not sure what I should do. What do you guys think/recommend? I am slightly lean towards running the long side with the width, thinking with the length I would get a bowling alley feeling. But I am also installing a drop (tile) ceiling (2x4') and the ceiling will be installed with the long side of the tile running with the length of the room, not sure if that matters........just looking for opinions. Thanks!
  2. jebatty
    jebatty
    Minister of Fire 2.
    NULL
    Jan 1, 2008
    5,353
    701
    Loc:
    Northern MN
    When I laid wood flooring in our dining room I had the same question. The recommendation I found, and I don't recall where, was to lay the flooring so it is parallel to the windows. Hope that helps.
  3. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    Hmm, just thinking out loud here.
    Since its laminate thermal shrinkage will be uniform width versus length so that's not a factor.
    There's the optical effect of shortening and lengthening. Kind of like how wearing vertical stripes makes a person look taller etc.So if you want to make the long room look more square then go parallel to the short walls.
    You'll have to make more cuts, and hence have more waste if you run parallel to the short walls.
    I vaguely remember something about windows too and think it was related to your sight line and the reflections you see of the windows. Not sure the effect though.
  4. EatenByLimestone
    EatenByLimestone
    Minister of Fire 2.
    NULL
    Jul 12, 2006
    5,666
    600
    Loc:
    Schenectady, NY
    If the flooring will be a different material than the floor in the room leading to it, I'd run it so the length of the pieces goes down the 27 foot long side. It's kinda like stripes on a fat person. You don't want them to go horizontal because it makes them look fatter. But making them look taller isn't bad.
    Matt
  5. Beetle-Kill
    Beetle-Kill
    Minister of Fire 2.
    NULL
    Sep 8, 2009
    1,849
    211
    Loc:
    Colorado- near the Divide
    Some laminates have a recommended max. run length. Check to see what the manufacturer suggests.
  6. greg13
    greg13
    Minister of Fire 2.
    NULL
    Jan 5, 2012
    639
    144
    Loc:
    CNY
    Traditionally you run the length of the room, but as Beetle said there are usually a maximum length of the run . Check the manufacturer's guide.
  7. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,024
    1,649
    Loc:
    Next to nuke plant Berwick, PA.
    When I laid mine, the directions specified running long ways. I ran 4 rooms worth, running into closets, and through doorways. Did one complete floor when done. Was a bit tricky in a couple closet front wall/corners, but came out real nice. A small cordless circular saw and a jigsaw with fine blade are your friend here. Wear a dust mask when cutting, stuff is nasty.
