Hey again - recap...I have a Orlan 60 wood boiler. I inherited this machine when I bought the house. I have a ton of questions, but not sure where to even start...so I'm just going to give you a run down of my last few days.
I have a large house - 4700 sq ft. - no hot water storage. I have an electric furnace and a gas furnace on opposite ends of the house. They both have hot water coils. I have asked for advice on settings in the past and have taken all of it.
We were out of town for thanksgiving so I let my boiler burn out and cool off as to be safe while away. We returned Sunday afternoon - to about 45 degree weather outside. I immediately started a fire and heated up my boiler. Both thermostats in my house were at about 66 degrees or so. I got a fire burning and got the boiler up to temp. I try to turn one furnace on at a time and heat up each side of the house, respectively, so as not to cool off the water temp in the boiler. It generally takes me several hours to get through this whole process - on a day/night when it's not too cold. One of my problems is I load up the chamber with logs until I can't fit any more in at 10 o'clock at night...and with my house up to temp on a moderately cold night...I get up at 5 and if I'm lucky it'll be at 165 with only a few coals left in the chamber. Without storage (which will be installed next summer if I remember in June how pissed I am in December) is there any way to get a longer burn out of the wood in my chamber??
The past four days have been the worst. I had been letting fire burn out at 5 in the morning since no one is home during the day. Then I start the whole process over again at 5:30 when I get home after work. The problem is the past few nights have been down to single digits outside. This morning was 2 degrees. My house gets cold - like 64 - and I can't for the life of me get it warmed up again. I'll get the boiler up to 172 or so...but as soon as the water is circulating and my furnace(s) is/are blowing cold air on the coils, my boiler temp drops to 144 or so. I open the chamber doors, get the fired burning big again, go in and shut down both furnaces, and let it heat back up to 170 (30 minutes later). By that time, any heat my house has gained is lost and I'm back at square one. With 170 on the boiler and 64 in the house. I turn a furnace back on, bam, water temp is back down to 150. I learned my lesson on not letting it burn out because its incredibly hard to get my house heated back up. Its been a viscous cycle and I'm so horribly frustrated I'm about ready to take it down and sell it and use the funds to pay for propane and electricity! Actually...At this point, I already am paying to heat it anyway and I'm just wasting wood to heat a garage that's already too small and smells like smoke. I've burned an incredible amount of wood trying to figure this thing out - and haven't heated my house one bit.
When my house is up to temp, it functions very well. But I've only had it working really well when I've been home for two or three consecutive days to get it going. I started at 5:30 last night and at 11:30 I told everyone to cover up cause it was going to be a chilly night. My house was still at 66 degrees and the boiler was hovering at 156. Along with everything else, I set my circulating settings (P144 up to 170…and Ph4 to a 5), but then when my house is 66 degrees and the furnaces are on...blowing the cold air from my fan...and my water temp isn't high enough to circulate...my house is basically getting air conditioned. Am I right? Or not even close?
All I know is my house is cold, the boiler isn’t working like I know it should and I'm bitter and frustrated. I need you guys to help a brother out!! The guy that sold me the house said "the house gets so hot during the winter we had to open windows." That means there's no way to control the heat and keep the boiler from getting too hot except to have the furnaces running to keep the water temp down...which seems dumb cause who wants a house thats too hot.....or two, he lied through his teeth. UGH!
I bought the house October 14th. With moving and running a business and kids, I chose not to go get wood. I bought a semi load of logs. Literally the wood I used on Monday was the same tree - literally - as the wood I used on Wednesday. Not sure what could be different......
