FYI... for those assembling their new chimneys (especially Selkirk's CF Sentinel/ Metalbest chimney products)... when assembling an exterior 'tee' to the wall support kit, make sure you remove the plug from the bottom of the Tee, assemble the entire thing, then put the plug back into the tee through the bottom of the support kit. There's a little tab to hold it in place and everything!
If... like me... you miss the tiny little blurb in the instructions... and assemble the whole thing with the plug in the Tee... then come time to clean out the chimney, you get the joys of figuring out how to support the entire chimney while removing the support kit, to remove the plug. The hole in the bottom of the support base is smaller than the outer lip on the plug... so you can't pull it out.
arrggg!
arrggg!
