Gas Valve or Thermocoupling on a Gas insert stove
clark5561 Posted By clark5561, Oct 22, 2008 at 9:12 PM
Thread Status:
  1. clark5561
    clark5561
    New Member 2.
    NULL
    Oct 22, 2008
    2
    0
    Loc:
    Lincoln, RI
    Hi!
    I have 15 year or older gas fireplace insert made by Gas Technology INC that will not run. Here is the problem my pilot is lighting fine but to get the burner to light I have to hit the gas valve then the burner will start right up another way to make it work is sometimes it will come on automatically after 15 minutes, but hitting the valve will make it start right away. I have a plain volt meter not a milli volt meter to check the system. Do you think it is best just to replace the gas valve since it seems to be sticking or do you think it is not warming up to make the valve open and then when I hit it I am forcing the valve so should I start there and replace the thermocouple first? Anyone have ideas???
    Mike
  2. blujacket
    blujacket
    Minister of Fire 2.
    NULL
    Oct 2, 2008
    615
    281
    Loc:
    West Carrollton,Ohio
    Thermocouple.
  3. Corey
    Corey
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    2,307
    162
    Loc:
    Midwest
    +1
  4. Redox
    Redox
    Minister of Fire 2.
    NULL
    Feb 23, 2008
    1,099
    0
    Loc:
    Burbs of B'more, MD, Hon!
    Do NOT try to repair or lubricate a gas control valve! The results could get ugly. If you have a combination gas valve that requires you to hold the pilot knob in and can get the pilot to stay lit, it probably isn't the thermocouple. The thermocouple holds the safety side of the valve open and the control side opens and closes to control the burner. A combination valve will have a single off-pilot-on knob.
    If it's really old, you might have a pilot that doesn't have a safety; in this case, the thermocouple is the safety for the main valve only. If you loosen the thermocouple electrical connection at the valve and the pilot stays on, it's the older style. In this case, it might be worth it to try changing the thermocouple. They're cheap; less than $10 at most hardware stores.
    Hope this helps.
    Chris
  5. clark5561
    clark5561
    New Member 2.
    NULL
    Oct 22, 2008
    2
    0
    Loc:
    Lincoln, RI
    Thanks everyone it was the thermocouple, replaced it and now works just fine.
    Mike
  6. Gooserider
    Gooserider
    Mod Emeritus 2.
    NULL
    Nov 20, 2006
    6,737
    10
    Loc:
    Northeastern MA (near Lowell)
    Note - post containing dangerous advice to attempt lubricating a gas valve deleted. This kind of high hazard advice is not welcome, and if continued, the poster making it won't be either...
    Gooserider (In MOD mode...)
Thread Status:
