Finally, the outside painting / storm install project is done, time to move on to other more important things, like getting the chimney liner installed.
But before I can do that I have to finish 'preparing' my firebox. The first part of that was to remove the last of the original damper assembly, shown here:
The course of bricks above the damper were built on top of it and I was afraid that without the damper there could eventually be a collapse so I added this steel plate spanning the distance with cut fire bricks at each end. I still need to goop some fireplace cement in there but it is in tight. Cement will be added tomorrow.
Here's a shot of the clean firebox, the problem I ran into was that to push the insert in as far as I wanted I needed to eradicate some of the existing firebrick, so today I spent a couple hours filling the house with dust and dirt leaving me with the results in the second photo.
I opted to only cut away as much of the fire brick as I needed rather than take it apart and rebuild it larger, which I could have done, but that would have delayed the project further. Also, I could have pulled and replaced the fire brick with cast panels which I suppose might have been pretty easy.....and far less dusty. BTW, I didn't tarp the fireplace when I did the cutting....which made a huge mess!
At least now I can say that I'm ready to install the liner, and the expanded flashing base cover will be done tomorrow morning. We have a few good days of weather left here but not many. I think that by Thursday / Friday we're back down into the 50's and I would like to have this fired up by then.
steve
steve
