Getting Wood Stove ready for Summer
partybob99 Posted By partybob99, Apr 22, 2013 at 10:20 PM
  1. partybob99
    partybob99
    Member 2.
    NULL
    Sep 21, 2010
    39
    0
    Loc:
    NorthWest, OH
    What are some of the things you do to get your wood stove ready for the Summer season?
    Some of the things I do are:
    • Clean glass one more time
    • Vacuum inside of stove and empty all ashes so it's completely clean
    • Close air inlet valve all the way on front of stove
    Do any of you put a towel or cloth into your chimney liner tube as it comes out the top of your stove to prevent air flow leaving from your presumably air conditioned room and going up the chimney? I havent done this yet, and it's my 3rd year, but I wonder if I should try it. Just have to make sure you remember to pull it back out before you burn again in the fall.
    thanks
  2. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    I just don't open the door again until September.
    northwinds, Defiant, jeff_t and 2 others like this.
  3. DexterDay
    DexterDay
    Guest 2.
    NULL
    I put a Damp rid in stove and will plug OAK and Flue. Helps to reduce exchange air and also eliminates any moisture problems.
    Rusting from the inside out may take a long time, but I plan on running my 30 for a Loooong time. I do this my pellet stoves also. Keeps the firebox clean and rust free.
    A note inside the firebox, to remind you of the plugged air and exhaust path helps too ;) Just in case you forget....
    Defiant and Jon1270 like this.
  4. Shari
    Shari
    Minister of Fire 2.
    NULL
    Oct 31, 2008
    2,327
    291
    Loc:
    Wisconsin
    Sounds good to me, DD but it will be some time before I can do that as we have snow in our forecast this week............
    Spring! Spring! Where art thou! :)
    Kevin Dolan and DexterDay like this.
  5. DexterDay
    DexterDay
    Guest 2.
    NULL
    I haven't done it yet myself. Its still cool enough some nights here.
  6. 1750
    1750
    Minister of Fire 2.
    NULL
    Apr 21, 2013
    529
    122
    Loc:
    Michigan
    I'm very new to this, but would think taking a look at the chimney would be a good idea before closing the door for the summer.
    How do any of you determine that your chimney does/doesn't need to be cleaned?
  7. Beer Belly
    Beer Belly
    Minister of Fire 2.
    NULL
    Oct 26, 2011
    2,026
    725
    Loc:
    Connecticut
    We also put a DampRid container in our stove after a thorough cleaning. The Wife will usually also put in some Birch splits, or decrotive Candles to give ya something to look at thru the glass
  8. Beetle-Kill
    Beetle-Kill
    Minister of Fire 2.
    NULL
    Sep 8, 2009
    1,849
    211
    Loc:
    Colorado- near the Divide
    Sorry, not even thinking about this until it stops snowing. 10" today, still snowing.
  9. KodiakII
    KodiakII
    Feeling the Heat 2.
    NULL
    Jan 17, 2011
    499
    99
    Loc:
    Eastern Ontario
    No summer this year, just a couple of weeks of bad skiing! Run out of good wood a couple of weeks ago, but am still buying pellets!!
  10. Jon1270
    Jon1270
    Minister of Fire 2.
    NULL
    Aug 25, 2012
    2,016
    1,128
    Loc:
    Pittsburgh, PA
    If you're new at this, you can safely assume your chimney will need to be cleaned at least once a year if you're burning with any regularity, and it may be more often than that.
    In my first season, which just wrapped up, I had to clean my chimney liner mid-winter because, thanks to my mediocre (damp) wood supply, the screen at the top got clogged with creosote and the stove stopped working properly. I had to brush even more creosote off that screen again in late winter, and a week or so ago I did the full cleaning again just to make sure everything's ready to go again in the fall.
    If everything is operating properly and the need for cleaning isn't obvious from the ground, inspecting means looking at the interior of the chimney, generally by getting on the roof or ladder, pulling off the cap and shining a flashlight down the opening. There are some people who do everything right -- maintain a supply of very dry wood, and operate their stoves very skillfully -- who can go several years between cleanings, but that's not me yet, and it's very probably not you either.
    Scols likes this.
  11. Beer Belly
    Beer Belly
    Minister of Fire 2.
    NULL
    Oct 26, 2011
    2,026
    725
    Loc:
    Connecticut
    +1
  12. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,635
    3,898
    Loc:
    Unity/Bangor, Maine
    Still burning once or twice a day . . . but when I do my final burn for the season . . .
    -- Clean out all the ashes and vacuum it out
    -- Clean the glass
    -- Lubricate the air sliding mechanism
    -- Clean the outside of the stove and hearth
    -- Sweep the chimney
    -- Put some baking soda and/or a candle inside the firebox to light if and when I get a reverse stack condition in the summer
  13. partybob99
    partybob99
    Member 2.
    NULL
    Sep 21, 2010
    39
    0
    Loc:
    NorthWest, OH
    What does that mean, reverse stack condition in the summer? I'm not familiar...
  14. jeff_t
    jeff_t
    Minister of Fire 2.
    NULL
    Sep 14, 2008
    4,163
    1,114
    Loc:
    SE MI
    I'll try to dig out all of the creosote I can, on the inside of the stove. I may or may not brush the pipe.
    At some point in the summer I'll get sick of looking at the nasty glass, and I'll grab a razor and some glass cleaner.
  15. jeff_t
    jeff_t
    Minister of Fire 2.
    NULL
    Sep 14, 2008
    4,163
    1,114
    Loc:
    SE MI
    It happens frequently to some, when the inside temp is cooler than the outside temp. Heat rises, cold air sinks.
  16. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,635
    3,898
    Loc:
    Unity/Bangor, Maine
    What he said . . . I sometimes see it happen once or twice in a summer . . . usually it's not a problem, but when it happens I don't particularly want to smell creosote so I just light the candle and let it burn for a bit to fix the draft.
  17. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Annual cleaning for us means cleaning out ashes but we do not normally vacuum the firebox. Then comes cleaning the catalyst and the glass.Then we check all gaskets. If any need changing (usually not) they get changed either right then or early fall.
    Close the door and forget it until fall. We will then check the chimney but we have not cleaned it since the summer of 2009.
  18. bag of hammers
    bag of hammers
    Minister of Fire 2.
    NULL
    Jan 7, 2010
    1,447
    451
    Loc:
    Northern ON
    Stopped at the place where I sometimes get hardwood milled ends (figured I'd pick up a skid and toss it in the pile for next year) - they finally put a skid out on the sidewalk this morning but it was gone before I got there (@ 8:30 a.m.). Last couple years I didn't have much trouble - take the occasional drive by and I'd see something out on the curb, and I'd grab it. This year they're getting scooped up fast. I think some folks in the area are scrambling for wood now with the never ending winter.
    But - its supposed to climb into the 50's this weekend - almost tropical...:cool:. I am already scrounging up the windblown and deadstanding stuff around the property. Got some empty pallets to fill up again, time's a wastin'....
    Edit - sorry to the OP - the above was my long winded way of saying the stove isn't near shut-down mode just yet....
  19. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Hold in there bagger. Spring will come...sometime.
  20. 1750
    1750
    Minister of Fire 2.
    NULL
    Apr 21, 2013
    529
    122
    Loc:
    Michigan
    I've looked around the site for an article on inspecting/cleaning a wood stove chimney, but haven't found one. This site is so comprehensive, I'm sure it's here somewhere.
    Would someone be willing to link me, or tell me where it's located?
    Thanks!
  21. bag of hammers
    bag of hammers
    Minister of Fire 2.
    NULL
    Jan 7, 2010
    1,447
    451
    Loc:
    Northern ON
    Thanks BS - yeah I know just getting older and grumpier I guess.
    (can I get kicked off this site for whining too much...?..)
    Backwoods Savage likes this.
  22. dyerkutn
    dyerkutn
    Feeling the Heat 2.
    NULL
    Jul 11, 2011
    280
    67
    Loc:
    Boston NW suburbs
    does that mean when it is not cold enough to burn around the clock you have to start from cold those couple of times?
  23. raybonz
    raybonz
    Minister of Fire 2.
    NULL
    Feb 5, 2008
    6,210
    1,036
    Loc:
    Carver, MA.
    I start new fires daily this time of year and this is where it's great to use Super Cedars.. From a cold start my stove is ready in under 1/2 hr. every time.. When the cold weather rolls around then I just reload after raking the coals forward..
    Ray
  24. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,635
    3,898
    Loc:
    Unity/Bangor, Maine
    Yup . . . gives me a chance to burn up all those pine cones my wife insisted I collect in the past few years . . . and while I love my Super Cedars for the quick and fast fire . . . I will admit that the pine cones work pretty well since I'm not in as much of a rush to get things going. I am using up quite a bit of kindling -- but I have a crapload of kindling as well . . .
  25. bag of hammers
    bag of hammers
    Minister of Fire 2.
    NULL
    Jan 7, 2010
    1,447
    451
    Loc:
    Northern ON
    such is the life of a weekend burner - all season regardless of outside temps - a few dozen cold starts here this year (and counting - thanks, old man winter...)
