Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I'm looking for good recommendations for what manufacturer and where to buy 4" PL.. I will be using this on an Harman PF100. Any help is always great! It can be Online or local to Manchester, NH area.
I just bought some 4"/6" Selkirk DT from a member. It is 4" pellet vent, with a 6" O.D. And the outside air is Pre-heated in the outer 2" ring, that flows around the inner vent. It will allow you the use of an OAK (which I highly advise) and also, only cut 1 hole in your home.
Pretty nice stuff. IMO. I have used and seen a couple different brands. All work, but some assemble better, seal better, and look better.
I bought my Simpson Duravent PelletPro 4 inch pipe from Dynamitebuys.com, they were the best price at the time. ...find the discount/coupon code to use for their website
I got my 4" Simpson Pellet vent pro pretty cheap from Kinsman Stoves (member), but I picked it up. Don't know what delivery would be and how large the pieces are that you need?
It leaked a lil.. But still works well and went together nicely
Not sure on the airflow capacity, as some pellet stoves have a 4" inlet for outside air, as far as I know that DT pipe only has a 3" fitting coming off it.
Thanks for all the info guys! I'm almost done plumping in the duct work. Then I will be getting the exhaust done. I will post a new thread with pictures when I'm done.
