Greenhouse wood furnace?
Rearscreen
805
Vermont
New England, from the state of stubborn, farmer wants to replace a woodstove for a wood furnace in the greenhouse. Any suggestions where to look? Does anyone make boilers of furnaces that heat air and can burn overnight?
At the rate your going your going to want a dual fuel (oil/gas/wood) Yukon-eagle furnace
www.yukon-eagle.com
All depends on how much money you have to spend/invest in it.
The smallest coal stoker stove can be used as well.
The yukons are way behind on technology. I would avoid them.
Burning through the night is a tough task for even most woodstoves. A woodfurnace is great because it can be EPA certified as clean burning and relatively efficient while having a huge firebox for lots of output potential. The ducting and forced air blowers allow you to really get some high output for a greenhouse.
Burning through the night though. That's tough. Unless your farmer considers that to be 8 hours. Then there are some options.
It's all about the fire box size, the BTU's needed, and the efficiency.
that's just the math. you can't cheat physics. how big is the greenhouse, what is the required temp in it, what is the insulation value, and what is the required burn time. this will give you the ballpark you need to look for in equipment.
you can gain some of that need in storage, either thermal or chemically in the form of wood in the firebox. there are some units that will deliver pretty well.
Their new EPA cert units are supposed to be out soon. Of course that impending deadline probably is helping coax things along...
There are plenty of stoves and/or furnaces that will go 8 hrs or more on a load...depending on what your heat load is like...if it is too high, then just go with a wood fired boiler. There are plenty of 'em out there big enough to do the job...
So, a little more info and needed help. The greenhouse has back up propane furnace units. But, because this is a farmer and food is not a priority for humans hence makes little money, she needs a wood furnace along with the propane. Are these my choices or am I totally barking up the wrong tree...
Hotblast (Northern tool) $1449
139,000 BTU
6.8 CF firebox no glass
Finicky, low output fan
Englander (Home Depot) $1199
100,000 BTU
4.6 CF firebox
Generally good reviews
Drolet EPA certified $1499
95,000 BTU
3.6 CF firebox
Thanks for any advice...
I would go Drolet, simply based on efficiency. Would not want a non-EPA unit, I don't think, unless willing to trade-off some things - like burning more wood, & burning dirtier.
The Hotblast will blast through wood supply, the Englander is middle of the road that some have found satisfaction with.
They have their heat load limits though & will only do so much - how much you want to do is kind of an uncertainty. If this is to replace just a prior LP unit, then LP consumption history the past years might help guess a heat load.
Dry wood is also a must. Is there a good reliable source of lots of dry wood? Like, say, 10 cords per year? That should be one of the primary decision factors in the whole concept no matter which furnace is picked.
There are more capable ones - such as Max Caddy. But then budget considerations would also have to come into play - something else the buyer will have to evaluate.
Thank you Maple1 very good advice and taking the time for a concise answer. She does have the wood supply, right now she just uses (along with propane Modine) a clunker of a woodstove meant to be in a hearth, ashes spilling everywhere in the greenhouse! Your Manhattan Project in your basement looks amazing....
I've seen greenhouses where they put heated pipes in the dirt, but have no idea what else is going on.
