Had to call 911 yesterday... (My Redneck invention)
THE ROOSTER
All is well, thankful for that. But I felt I needed to tell everyone that no matter what you do to help something or make it better it can still cause a unforeseen hazard.
For YEARS I have been blocking off the area where my pellet stove heat output comes out, when the stove is off, I used a flame resistant piece of foam. To make a long story short as possible, I shut stove down yesterday late morning, got dressed to go do yard work once stove had completely shut down I installed foam (seems to cut down on the draft from OAK when it's windy outside) and headed out. An hour later I came in, to a house filled with smoke every smoke detector going off, couldn't see 2' in front of me.it smelled electrical, so I took a deep breath and headed in to find my pellet stove burning, igniter hadn't been working for at least 2 years, so I thought. I had turned knob just slightly past off, to room temp, once temp dropped below 70* it kicked on... So glad dogs were with me. Totally my fault, felt stupid looking at a bunch of firemen as I finally figured what it was...
I'm sure we all "McGuyver" things, just hope mine & telling it here possibly saves someone the 15-25 minutes of horror I experienced yesterday. Not to mention having to open every window on a 38* day...
I take it that the stove in story is a Harman? Had a bad pot switch start the stove when in off too. Just used most of the pellets in a unused garage though:)
Reactions: THE ROOSTER
I don't understand. It sounds like you are blocking off the convection air path.
There shouldn't be any connection between the OAK, which supplies combustion air, and the convection air path.
So, what am I missing?
Probably just my, "stupidity"... It seems to me that when the stove is off on a windy day there us a draft in that area.
Well said.
Glad to hear things weren't as bad as I had imagines when I first read the title.
Andrew
If your stove is off on that day It must be warmer outside, so DONT BLOCK IT EVER AGAIN!!.....hehe
Glad you and the dogs are OK. I have my stove in Room Temp and let it determine when to shut down and when to fire. It took a lot of finageling but when I got the room sensor placed just right the temp control became excellent. When I shut the stove down for ANY reason it gets unplugged unless I'm gonna be in the house and fire it up again. I've found that the OFF setting can be a bit touchy. I do have enough confidence in the stove that I leave it burning in auto mode when we go out. Never had a problem knock wood.
Unless your exchanger is cracked theres no possible path to the oak. Maybe you should check the exchanger if your getting a draft
